Anyone using a Speedhut tach?
I was able to get the tach to show a reading by feeding it a rectified 12v AC signal so I know the tach still works. Should I try a lower value pull-up resistor? Am I gonna screw up my PCM?
Attachment 713350
Had trouble with 3 of the 6 gauge set. Don't think I would use them again.
The tach is the only thing giving me issues, they just replied with this:
[QUOTE] I will be happy to help you with your issue. If you are concerned about getting the signal from the PCM with the pull-up resistor, I would recommend getting the signal from a trigger wire off one of your coil packs instead. You would not need a pull-up resistor if you go this route.
Thanks,
Ammon[/QUOTE]
Maybe I should have just done it this way in the first place, but I like wiring everything up as if it was all OEM. I like the fit and function of everything to appear stock. I even went out of my way to make my dash look factory. So far only one person has ever noticed my dash isn’t stock.
