Engine swaps - what power steering fluid did you use?
I've purchased PS fluid from the dealership because I read to only use recommended fluid but I've used Prestone PS fluid without issues.
The following users liked this post:
CattleAc (06-22-2021)
I added a filter to the return line. Every couple of years I use a turkey baster to empty the reservoir, refill it with new Type F, drive it around the block a few times, and repeat that twice more. Fluid always looks brand new. Not a hint of a leak anywhere almost 5 years on.
Jimbo1367 (06-18-2021)
G Atsma (06-17-2021)
G Atsma (06-19-2021)
Whichever part is more expensive to replace is what recommended fluid I use. Porsche recommends cfh11 fluid and I have used that with the ls1 pump. The pump is easier and less costly to replace. Alll other times I use ATF.
Michael Yount (06-20-2021)
Agree with matching the fluid type to the most exensive or most difficult component to replace when mixing and matching for a swap.
My 2006 Silverado daily driver, these have a history of noisy pumps. I swapped fluid to lucas and it quieted down. Each oil change Ive been removing fluid out of reservoir with a vacuum pump, same qty as a new bottle of lucas, and adding new fluid.
Looked in the Ford manual and it calls for Mercon ATF. The pump I installed is from a 04 Chevy and from what I can find both PS fluid and ATF are the recommended fluids. This kinda stuff drives me crazy. One this is for sure, the rack is a HELLUVA lot more work to change out and more money especially once you consider an alignment would also be needed. I'll probably try the ATF and as long as the pump doesn't make noise I'll be happy.
But I wonder if ATF and PS fluid are so dam similar that it doesn't really matter....
Just had to replace the pressure hose on the 01 and I was so glad that I did away with the plastic pulley. I would have had to remove it in in order to remove the pump and reservoir just to remove the line. Didn't have to drain it as it was all under the car and what a mess that was to clean up but topped it off with Prestone fluid and steering is smooth and effortless.
I just use off the shelf O'Reilly brand PS fluid. No reason to go crazy imo but I do see the appeal of using the recommended and would not knock you for doing so.
Power steering is one of the least critical hydraulic fluid apps going. As said, just about any ATF will do it. ATF has a higher detergency level for keeping trannies clean internally. Otherwise little difference between it and PS fluid
