high idle lq4 swap s10
2003 lq4 DBC, green blue pcm, swapped into a 1986 s10. engine idles high. i deleted maf egr vats all tranny codes (fmvb 4l80e) is installed. no vac leaks what so ever. even used a smoke machine. i use hp tuners for tuning. the engine is stock with no mods. im losing my mind this thing was working before. even changed the pcm and iac same **** please help
It just may be possible nobody has a solution for you YET. Would you rather a bunch of internet BS to sooth your butt-soreness??
Give it some time and quit being a whiney butt and telling those who may still help you that they suck.
Now nobody feels like helping you. YOU did this....
The following users liked this post:
CattleAc (10-13-2021)
k cool do you have a solution? an idea anything, oh senior tech member
G Atsma (10-13-2021)
it has nothing. i even smoke tested the intake with the rockers loosened. i can bring the idle down with my finger if i stick it in the iac hole. its also a new iac unit
Did you try adjusting the throttlebody adjustment screw? It opens or closes the butterfly but you need to reset the iac after each adjustment.
https://ls1tech.com/forums/pcm-diagn...learn-tps.html
https://ls1tech.com/forums/pcm-diagn...procedure.html
Google Russ K idle config. You have given absolutely nothing. You have tried everything? How about what you did, step by step, in order of how.
And this is a stock cam, stock intake, stock tb? Have you hooked up a vacuum gauge?
What is the commanded idle at say 160*, what are you actually getting? Again, no info.
