LS Headers on Blazer K5 4X4 Frame
Any firm experience or fitment you guys can point me to
thanks
1972 K5 Blazer - LS3 - 408 Blueprint 580HP - 6L80E - 208 case - 8'' lift - Dana 60/14 bolt
Pricey but they have pictures of them installed. https://www.motorcityk5.com/i-13149-...=category:9893
Doug Thorley Tri - Y's
Scheonfiied are the two that I have seen also
Was hoping someone had tried the Hooker, or other brands
I am running the 1-7/8 Doug Thorley tri-y's. I remember needing to trim 3/8-1/2 off the top of the frame rail on both sides (top leg of the C channel of the frame). Been running the truck for 4 years, no problems with the headers since install. Only problem I had was the rubber in the clamshell engine mounts that came with the kit shifted/sagged, so that the engine started hitting the crossmember. I jacked it up in place and filled all of the voids with Windoweld to make them more solid, and it's been fine.
A few pics, but not showing it real well:
http://67-72chevytrucks.com/vboard/s...d.php?t=770894
How stuck are you on headers? The 2010 Camaro manifolds fit a 73-87 frame beautifully. The bellhousing was left in the stock position for this. I can't say for sure what would happen if you used Tejas mounts or something similar.
