Help me with these ports please!!
- PICTURE #1 I know this is the EVAP purge but what’s the easiest way to cap this? Also can it be in threaded and used for the MAT sensor location for the terminator X harness by chance?
-picture #2 not sure where this is supposed to go.
- picture #3 I’ve seen this in other builds go to a port on the throttle body but I don’t have that port on mine.
- picture #4 I hooked this line to the booster posted in picture #5 since it had that on it, is that right?
Pic #1, where you put the MAT sensor is a debated topic, some like In the inlet runner pre throttle body, others say anywhere on the intake manifold. regarding the Evap purge, not sure about that one.
Pic #2 is the steam port and ties back into your coolant system.
Pic #3 Is the passenger side PCV breather, there should be a port on the drivers side of the throttle body, it plugs into there, again, PCV is another widely debated topic about its efficiency, longevity, and exact routing per your individual choices.
Pic #4 Is also PCV venting? It looks like your valve covers have a couple different routing? hard to tell, literally do a search for PCV routing and your whole day will be busy.
Pic #5 is the brake booster and that should connect to the large port on the back drivers side of the intake manifold.
unless one of those ports has an attachment nipple I can get somewhere that can be screwed in
the vent on the valve cover in picture four goes behind the intake and is the same line going into the booster in pic 5 the engine came with that connection on it so I figured that’s where it went. Just wanted to make sure
On #4, I can't tell for sure where that's coming from in that pic, but it looks like you have a hose coming off the valve cover. If that is the case, that should not be going to the brake booster. There should be a large vacuum port on the back of the intake that goes to the brake booster.
1.) EVAP Emission goes to fuel tank
2) Steam crossover goes to the radiator
3.) Goes to throttle body
4.) Connects to the intake manifold and the back of the valve covers (Check PCV valve in the line before going into the intake manifold)
5.) Brake booster and connects to the back of the manifold.
and on number 3, I don’t have a spot on the throttle body for this, I’ll link the TB I have... maybe I have to take out one of the plugs in the TB? That’s what I’m confused on
https://www.summitracing.com/parts/f...RoC24UQAvD_BwE
EVAP is not one of my strongpoints but I think it's for ventillation of the gas tank.
