Noob questions
The first is an LQ9 4L65E setup—my main question here is do I need to find a 2WD Escalade or is it simply removing the transfer case with the trans being the same.
The other option I am considering is an L33 ONLY because of it being an aluminum block. Are these unicorns and I shouldn’t hold out for finding one?
I am leaning away from Gen IV engines to avoid AFM/DOD.
If I am going to use an aftermarket wiring harness, do I need the truck harness? Not sure I want to try to sort through the harness myself and if I am going to pay someone, why not just get an aftermarket? Not sure I fully understand the cost associated with this.
This is the early planning stages so any additional thoughts? There are a ton of engine paths to take but I am likely focused on the LQ9 unless you can convince me otherwise.
Thanks
The aluminum 5.3's are getting pretty hard to find depending on your area, and do go for a premium over say the LM7, which are plentiful in relation. You can delete AFM/DOD if you find a good deal on a Gen4, pretty simple deal there.
If you use an aftermarket harness, like say the Terminator X Max, that will just control the engine and the trans, so you will still need to thin out/sort through your cars harness if you want to remove all the stuff that would be redundant. If you find the right engine, make sure it does come with the harness just in case, you can always toss it later, but getting an OE harness after the fact isn't easy.
Small cam and headers along with a good tune you will be close to 400 rwhp.
In my C3 I had 3:73 gears. Great combo with the 4L60E.
If staying with a fairly mild engine combo and a GEN 3 LS (like the LQ9) I like and use an aftermarket engine harnesses. I've used both Speartech and Howell with very good success. Gen 3 LS engines only need one ECM for the engine and trans.
Rick
You can't convert a 4wd trans to 2wd without spending money to tear it down. If you find 4wd donor for the right price you can buy a good used 2wd trans separately. Get the same model/year trans as the 4wd donor in a 2wd version so wiring and computer are the same.
As for the harness, go with the OEM harness: at least you know for sure it will be the correct one for your combo! Have it modified and the computer re-programmed by a specialist (Speartech is excellent, very helpful), and you are set, it is really plug-and-play!
One good way to go is always to buy a donor vehicle (pick up, Tahoe...) and get everything you need for your swap (including little things like fuse box, relays, ...).
A few years ago, I have found an LQ9 with 10,000 miles on it, a trans with 8,000 miles on it: look around a bit, you will not even need to have it rebuilt!
If you PM me, I can help you better with more specific parts for your car. Speedtech and ICTbillet are your best and cheapest options. Stick with gen 3 engines and transmissions. Makes first time swaps MUCH MUCH MUCH easier.
