Using a Cable driven VSS with speedo ratio adapter box
Old Sep 12, 2022 | 10:38 AM
Winchested's Avatar
Default Using a Cable driven VSS with speedo ratio adapter box
What would be the proper way of installing the VSS (Dakota digital 8k ppm) pass thru with a speedo ratio adapter box?
Tcase output--> VSS--> Ratio Box
or
Tcase output--> Ratio Box--> VSS
This will be on a 5.3/NV4500 w/ doubler/ dodge NP205
Originally my Dana 300 Output with 35's and 4.88 gears was perfect with stock output and with 5.38s and 40's its pretty much spot on too, but I'm assuming going to the new tcase may change that ratio. I likely wouldn't know how far off it is until I was able to Match it to GPS speed when doing 50- 60 Mph.
Thanks for any insight.
Old Sep 12, 2022 | 11:42 AM
The "High" speed ratio should still be 1:1, so I fail to see the issue with changing transfer boxes
Old Sep 12, 2022 | 12:33 PM
Winchested's Avatar
This would be correct if the transfer case was being installed with stock sized tires and gears? But most all transfercases have different tooth pinions to get the correct ratio for gear/ tire. Hence the ratio box rather than changing pinions as most of the pinions are long out of production due to computer reluctor VSS now.
Just trying to wrap my head around it.
Old Sep 12, 2022 | 12:53 PM
garys 68's Avatar
If you're not running anything off the VSS other than an ecu signal, it doesnt matter. The function of a vss is primarily to avoid stalling with a manual trans.
Old Sep 12, 2022 | 01:28 PM
Winchested's Avatar
I do want to eventually be able to use cruise control with a dash mounted 4 button deal (Dakota digital or the like) that is wired into the TAC module.
Old Sep 12, 2022 | 10:31 PM
garys 68's Avatar
The pulse rate of the dakota digital VSS is not high enough to work with the stock ecu. I had to use the reverse gear (39 tooth) on my T10 to get my DBW cruise control to work.
Old Sep 13, 2022 | 05:08 AM
Winchested's Avatar
Interesting Gary thanks.
I did find this over at HPtuners
https://forum.hptuners.com/showthrea...l-8K-Pulse-VSS
Saying there is the possibility of changing the signal in the ECM.
Old Sep 13, 2022 | 06:43 AM
wave1957's Avatar
Since you are using Dakota Digital parts (VSS, cruise), have you tried asking them how to make it all work?
Old Sep 13, 2022 | 07:13 AM
Winchested's Avatar
Yes they suggested using their SGI-100BT which just amplifies the Signals for tach and speedo ref. But it's another $150 and adds more wiring mess into the mix.
This is why I was hoping to be able to just have the ECM adjusted to read the 8k ppm signal. Which seems doable I just need to find the right tuner.
I'm starting to think you'd want to run the VSS after the ratio box so the ECM is seeing actual speed at the 8k ppm.
Watching Brendans (LT1Swap) Vids on Youtube The cruise uses a 4k ppm Signal from the ECM. So the ECM must convert the OE 40k ppm signal.
Old Sep 15, 2022 | 02:04 PM
garys 68's Avatar
You can adjust the ecu to read the correct speed, it's just the rate is not high enough for the dbw cruise control to work correctly. It wnt from idle to wide open every second. ECU read correctly, but doubt the ecu was reading a stable signal for cruise.
Old Sep 16, 2022 | 05:55 PM
Winchested's Avatar
You're saying this was your experience?
I might just abandon the cruise option for now. The wiring is there. Can buy the Dakota digital box later on ,the 4 wires are all set up from the TAC module connector so it would just be tying in the clutch disengage, brake and brake switch.
I assume with a manual I don't need the TCC wire I added a pin for the Clutch switch on pin 35. Don't want to run the clutch engaged for start switch, I'll just get that code deleted in the tune.
Old Sep 17, 2022 | 07:39 AM
garys 68's Avatar
Yes, tried it with the DD VSS, no luck even with the correct speed tune on the ecu. Used the 39 tooth reverse gear in my T10 as a reluctor, worked fine. Oh yaeh, I did have to retune for the correct speed since the ecu thought I was going 140mph at 35 mph and limited my top speed, lol.
