G Body LS swap TAC module APPS help needed
Old Dec 7, 2022 | 12:19 AM
queezy's Avatar
Default G Body LS swap TAC module APPS help needed
Hi,
this is my 1st post here and my 1st LS swap. I’ve gotten to wiring and I’m having trouble with my gas pedal. I have a Gen 3 2006 5.3 with tac module and wiring. I saw that the Gen 4 could use the impala pedal after being repined. Does anyone have any experience with this or know how to get this tac to work with the impala pedal?
I’ve tried 2 different TAC models and 3 different Impala pedals. I keep getting the same permanent and pending codes: p2138, p1125.
I tried moving the pins around on the pedal harness and still get the codes. When I’ve tried to start the car, it will fire and idle I just don’t have any pedal response.
any help would be appreciated, I’ve hit a wall and have moved to working on the shift linkage and finishing up the digital dash install until I can get some help or find an online resource.
I’ve added photos of the schematic I used to wire my pin. Hopefully someone else has run into this(and I explained it correctly).
tac part #
  • 12573059
  • 1259008
pedal part # (6 pin)
- 25830023
- 84018392
​​​​pcm - 06 Silverado
Old Dec 7, 2022 | 06:23 PM
ls1nova71's Avatar
Have you tried a truck pedal? GenIII's are more picky on having matching parts, so the GenIV Impala pedal may not work.
Old Dec 7, 2022 | 06:28 PM
queezy's Avatar
I haven’t. Honestly, I’ve been trying to avoid it because I don’t have a welder or know how to fav up something that fits a g body.
Old Dec 8, 2022 | 10:03 AM
dlwilson's Avatar
Here's a different idea. When I got my 2000 Corvette LS engine it came without a TAC module, and they are like $500, which I was not going to spend. So I got a drive-by-cable throttle body for the same year Camaro, and repinned the harness to be for a DBC throttle body. The swap still isn't running and driving, but I plan to use overwrite the bin file in the PCM that came with the Corvette engine, with a bin for the same year Camaro.
Old Dec 8, 2022 | 12:31 PM
blackhawkMC's Avatar
The chances of the 2006 PCM having the right hardware is going to be slim if it wasn't from a van.
https://lt1swap.com/cable_conversion.htm
Old Dec 10, 2022 | 01:33 AM
queezy's Avatar
The truck pedal worked but created a new issue… How do I mount this pedal with the crazy offset? Has anyone mounted this pedal in their g body?
Old Dec 10, 2022 | 09:48 AM
ls1nova71's Avatar
You would have to find a spot under the dash and build a bracket for it. It won't be where the factory pedal mounted, but closer to the column. You could make a plate that bolts into the stock location, then put a couple bends in it, towards the firewall, then bend back to the left, again nearer to the column, then mount the pedal to it. It would have to be pretty thick metal to keep it from flexing though. As an alternative, you may be able to get an older pedal that is metal and cut and weld it, but if you don't have access to a welder that's not going to help you.
Old Dec 13, 2022 | 10:17 AM
Project GatTagO's Avatar
Another option is to ditch the OEM computer, get a Holley EFI system, and use their bracket for G-bodies:
https://www.holley.com/products/engi.../parts/145-140
Then you can use a C6 Corvette pedal.
Andrew
