6l80 into 2000 silverado
That is, until yesterday! Look into the recent threads about the new Holley V3 transmission controller.
It's brand new, so you be the one that may let us know how it goes. 😁 There's a member on performancetruck.net that's pretty familiar with the Holley ECUs and is going to be running the 4L and 6L back-to-back on the 1/4 mile. Pretty sure it's going to be on the GMT800 generation trucks (NBS.)
Check it out: https://www.performancetrucks.net/fo...4/#post5521464
If it was me trying to do what you are doing, I would personally look more at the 8L90e take outs. They are super tough transmissions out of the box with something like a 700 lb torque rating and you would still need to use a stand alone controller so you would be in the same spot, but with a much stronger transmission and 2 more gears.
Tommy the answer is yes the majority of your stock components will work. Obviously you will need a torque converter but the 6L80 is a direct bolt up. Depending on your truck configuration you may or may not need a driveshaft, some do some don't, and it will use your stock trans crossmember with a slightly elongated bolt hole. The trans will require a standalone controller. Zero Gravity Performance has one or you can go to Holley which really would be ideal for this swap. The ZGP controller works but there has been some issues with getting some of the lighting to properly work. I know there are guys that have done this swap perfectly without a hitch but some are still struggling with that portion.
Tuning your current PCM will have no issues.
4wd is a little different beast. I cannot remember how that works so I am of no help there. Manual 4wd would be ideal in this scenario probably but would require an adapter of some kind to bolt it to the trans.
It really is not a bad swap but it will take some work. Physically it is super easy to install but getting that ZGP controller to work right is so-so.
I was under the impression that this swap was not possible in the GMT 800. I've skimmed through that TM-2650(?) long thread on PT.net, but I guess I missed if guys had made that swap? 🤔
Regardless, the new Holley option seems like a good setup and the physical swap is the easy part. The electronics and ECU/TCU is the challenge.
Ditto on having a good tune for the 6L...
There were some swaps done prior to this guy as well. https://www.facebook.com/watch/?v=429589408292988
Awesome! Thanks for the clarification @1FastBrick !
