LS3 into a 2002 Z28
After a long time dormant, I'm finally working on my LS3 swap again.
The LS3 came out of a 2014 SS 1LE. For external purposes, it is a stock LS3 wearing LS1 F-body front accessories and using an LS1 F-body engine harness. At the moment, I'm working on figuring out all of the routing and connections — electrical, fuel, vacuum, etc.
I have the following worked out:
1. Fuel injector adapters (using factory LS3 injectors with my stock LS1 engine harness via these adapters)
2. Cam sensor relocation (factory LS3 sensor on the timing cover, using an extension/adapter to reach back to the LS1 connection point at the back of the intake)
3. MAP sensor relocation (using factory LS3 intake with sensor near the throttle body, using an extension to reach back to the LS1 connection point near the back of the passenger side valve cover).
4. Oil pressure sensor (using factory LS1 sensor, screwed into the LS3 valley cover, and plugging directly into the LS1 harness).
I am still working on the following:
1. Knock sensors
I originally read something that said an LS1 PCM could be reprogrammed to work properly with LS2-style knock sensors, so I have a pair of those with the Racetronix adapter mounted right now. But I kept reading, and I'm now convinced that I need LS1-style knock sensors. So, I purchased two of those, and I am pretty sure I need a different Racetronix adapter.
ICT Billet sells little adapter blocks for mounting LS1-style sensors to the side of the block, but I thought I could just screw the sensors into the same place I bolted my LS2 sensors? Is there some reason I need those adapters?
2. PCV dirty air connection from valley cover to the intake manifold
I found a part number for the this one (12599298), but it doesn't seem to be in stock anywhere. SDparts.com seemed like they might have it (website says call to check stock). I just went ahead and placed the order without calling; they refunded me a few hours later.
From the photos I've seen, factory hose seems to have some sort of twist-lock connector on each end, but the connection points on the throttle body and on the valve cover don't seem to have any provision to work with such a thing. I'm thinking I can probably just get a piece of 3/8" vacuum hose.
3. PCV fresh air connection from throttle body to valve cover
The LS1 part number is 12556454. I think this will work for me, but again, this is a hard part to find! I could probably just use 3/8" vacuum hose here too.
4. Vacuum connections and routing
In particular, the connection for the AIR system, which I've removed completely. I'm probably going to get a straight-through connector to replace the tee behind the intake. It seems like most people just cap off the third leg of the tee, but I feel like my way is cleaner, and the little straight-through connector shouldn't cost much more than a set of assorted caps.
5. Evap solenoid mounting
I definitely do not want to delete EVAP — my wife would make me sell the car if it ever had even a hint of fuel smell and I told her "it's supposed to smell like that."
I'm using all factory LS1 stuff here, and the tube from the valve to the intake manifold plugs right in to the LS3 manifold. The only problem is that there's nowhere to mount the solenoid. (The manifold has a slot that the mounting tab fits into, but when the solenoid is mounted there, it interferes with the coil brackets.
One option would be to just ziptie it to the fuel rail, but that'll be ugly and hacky. If there's a cleaner mounting solution, I'd like to know about it! I could use this extension to permit relocation, but I'd have to re-figure the valve-to-intake tube and come up with some kind of mounting solution.
Another option would be to shift the coil brackets with some spacers and longer bolts. I'd only need half an inch or so. Seriously considering this option. I'd also consider fully relocating the coils, but that's a lot of work.
6. Mounting tab on driver side upstream O2 sensor connector
There is a mounting tab with a bolt hole attached to the wire-harness end of the driver side upstream O2 sensor connector — the one near the alternator. Can anyone tell me where it mounts? While we're at it, I'd also appreciate it if anyone could tell me exactly where on the block the ground strap is normally connected. I know it doesn't strictly matter, but I'm not seeing a spot that seems right based on the lengths of the various legs of the harness and what else those have to connect to. Maybe there is a bolt hole on the LS1 block that isn't present on the LS3?
7. Mounting bracket on engine harness at rear of engine
There is a metal bracket around the engine harness on the thick leg that goes across the back of the intake manifold. Based on position, it seems like it's supposed to bolt up to the passenger side head. If anyone has a photo of what this is supposed to look like installed, I'd appreciate it!
If anyone here has relevant experience on any of these, I would appreciate any feedback or suggestions!
ditch the pigtail on cover. Get a Michigan motorsports harness on amazon and plug directly into cam sensor. Avoid wire swapping crap.
yup
yup.
1. Knock sensors
You can drill and tap block for ls1 sensors. Sensors have to be ls1 style. You can use those adapters from ict I guess. Get a sensor extension harness.
Cap driver valve cover. Go from valley tray to intake. Passenger valve cover to throttle.
Ziptie evap to rail. Leave evap installed.
You want me to remove the curved thing and get the other kind of adapter that plugs directly into the sensor? Why?
That’s the thing I don’t want to do because it’s hacky and ugly. I bought some longer bolts and some aluminum standoffs which should shift the coils away enough for everything to fit nice and clean. If that doesn’t work for some reason, maybe I’ll try the ziptie route.
Again you can do it either way. But if the wires don't match up it will throw a code and have hard starts. Just a heads up. Gives lots of people headaches.
1. Knock sensors
Just drill the block ls3 sensor location for the ls1 thread size. I used the Racetronix extension listed here:
https://www.racetronix.biz/p/knock-s...s1ls1/ls2-ksrh
I have about 1500 miles on my setup and it has worked just fine.
And here’s the ground strap, which I’m quite sure is not where the factory attached it to the LS1 (Ignore my hand).
And here’s the wire harness bracket I’m asking about in #7.
On the passenger side, there's one too -- but this one is ahead of the engine mount, right behind the LS1 factory air conditioner location:
There is another hole with the right threads on the passenger side aft of the engine mount, but the knock sensor would interfere with the starter if mounted there.
Is there any reason these locations would give me trouble?
Also, I saw something somewhere about protective boots that go over the knock sensors (although it was in the context of the 5.3 in the Silverado). Is that a thing I need to worry about, or is it okay for the sensors to be mounted in the open with no protection, as shown?
As it turns out, there is a threaded hole on the driver side of the LS3 block which accepts an LS1 knock sensor without drilling and tapping. It's aft of the engine mount:
The most obvious issue using the location by the starter avoids, is the forward location is impossible to get to when the motor is installed in the car. You would have the engine mount in the way behind the sensor, and the ac compressor in the way infront of it, and the header covering it from the top, k-member from the bottom.
I have a tubular K-member, so that might make the sensor more accessible. Also, unbolting the AC compressor and swinging it out of the way isn’t a big deal.
https://ls1tech.com/forums/pontiac-f...l#post20494780
because in the lower location the wire would touch the exhaust
In post 15 on the passenger side I definitely left it in the location closest to the starter
I can see it in the bottom pic on the passenger side, in the rear location by the starter
https://ls1tech.com/forums/pontiac-f...l#post20494878
The LS1 oil pressure sensor I ordered came, but it was the wrong part. The connector was the right shape, but it had three pins. The correct connector has just one. It also had the wrong thread size (much smaller than it should be). I will be returning that one, but I ordered another from a different vendor (Tick), and that one fit perfectly on the harness and had the correct threads for the block; no adapters required. It’s significantly taller than the LS3 sensor, but it is lower than the intake manifold with the harness plugged in, so I don’t think it’ll be a problem.
I’m very nearly ready to reinstall the engine! Just a few final things to button up. I’m getting excited! It’s been nearly six years. 😭 (I still have lots to do before after the engine is installed, of course.)
Question 1: I think these two connectors on the sides of the engine bay are for the wheel speed sensors. Can someone confirm?
Question 2: I have two dangling connectors from the harness. One for the AIR solenoid on top of the engine, and another at the front left of the car where the AIR pump used to be. I’ve completely removed AIR. Do I need to cap these? Do they need resistor connections like I have to disable skip-shift without setting a code?
I’m assuming that I can disable AIR in the PCM, and that neither of those will be necessary, but that I should still close off the connectors so that they don’t get wet or corroded. What have others done here?
