C5 PCM Questions
1) Looking at some f-body PCM pinouts, it looks like there's two PCM Ignition pins at Blue 19 and 75. The pinout diagram for the C5 only shows a single PCM Ignition at Blue 19. I just want to confirm that is the only pin I should consider moving in to the fuse block or am I missing something?
2) I'm converting to DBC since I already have a DBC throttle body (engine didn't come with a TB). I removed the 6 wire DBW TPS wiring and am now working in the new 3wire TPS sensor. I'm following the guide at https://lt1swap.com/cable_conversion.htm. It shows that the 5V ref and low ref pins go to Blue 8 and 60 respectively, but for the blue/green PCM connectors. After the table showing the pins, Brendan says if converting DBW to DBC on red/blue connectors to the schematic he linked (also shown below). Reading this I see the sensor signal wire going to pin 24. I'm not sure if the other two pins go to the red or blue but my issue is that on either connector, the pins 46 and 54 are occupied. Right now this is what's in those pins:
Blue 46: None
Blue 54: MAP Sensor Ground
Red 46: MIL
Red 50: VSS Output
So I'm a bit confused where to pin the new 3wire TPS. Any help is greatly appreciated.
As far as the TPS, it looks like the throttle actuator control TAC module handled all TPS signals. The C5 PCM pinout doesn't show anything for TPS, only for throttle actuator serial data. Is the TAC specific to corvettes? Maybe I need to flash my PCM to support added TPS pins
Actually, looking at the chart here is where I must have gotten that idea. I'm not sure why Blue 19 is highlighted blue since Brendan indicates that is something to be added. Looks like he also added a wire at Blue 75.
https://lt1swap.com/99-02_vortec_pcm.htm
https://www.mrk-motorsports.com/pdf/...%20Pinouts.pdf
If you use a 100 psi sensor, you simply need to do some math in the scanner.
I actually use it for fuel pressure.
