Harmonic balancer question
Old Nov 15, 2024 | 02:23 PM
Bremer's Avatar
Default Harmonic balancer question
Hello, looking for advice with my swap.
The L9H that I purchased will go into a vehicle that is very space-limited under the hood, especially front to back. For that reason I have been looking into how to reduce the overall length of the engine.
If I replaced the harmonic balancer with one from an LS4, by how much would that shorten the engine at the front compared to say a Corvette balancer?
I am not looking to machine the crankshaft to get the balancer to sit where it would sit on an actual LS4, or even replace the crankshaft with one from an LS4. All accessory brackets would have to be custom.
I searched this topic and could not find the answer to this.
Thanks very much!
Old Nov 15, 2024 | 03:43 PM
Kawboom's Avatar
You really cant get a shorter engine in overall length than the older LS1 / LS6 "High Mount" accessory drive, but even it doesn't get you much.
the LS4 accessory drive is weird.
If the LS engine doesn't fit, there are plenty of other options, including the new 4.3 LV3 V6 that is literally a LT1 engine with two cylinders chopped off, like the old 1990s 4.3, but unlike the old 4.3 it's actually good.
Old Nov 15, 2024 | 08:21 PM
fieroguru's Avatar
The face of the LS4 harmonic balancer is 2 3/4" from the face of the block and is the most compact.
Here is a truck water pump for comparison:
However, it isn't compatible with any of the non-LS4 water pumps and accessory brackets due to the shorter offset.
So you either have to use the LS4 water manifold monstrosity, or go custom.
Stock LS4 accessory drive:
Old Nov 15, 2024 | 10:52 PM
1FastBrick's Avatar
Keep in mind the LS4 Crankshaft snout is shorter than a standard LS crankshaft.
I posted some measurements in this thread https://ls1tech.com/forums/forced-in...l#post20270246
Old Nov 16, 2024 | 06:04 AM
fieroguru's Avatar
The published length differences between the LS4 crank vs. the standard (not the early longer ones) are:
  • 10mm shorter on the accessory end
  • 3mm shorter on the flywheel end
The LS4 crank sits shallow in the LS4 balancer. If needed, a washer around the OD of the balancer pocket could be used with a longer crank. The use of the LS4 balancer on a non-LS4 engine is pretty common on the rear engine Porsche swaps.
Old Nov 17, 2024 | 02:26 PM
Bremer's Avatar
Thanks FastBrick and Fieroguru, great information.
With the current truck balancer the engine measures about 26.125'' long (front face of balancer to rear of block). Using the LS4 balancer, that reduces to about 23.225'' (not counting the protruding bolt head). Using the Corvette balancer, this dimension would be 24.55''.
Since I have 24.5'' available before the balancer hits the steering rack, I'll be using the LS4 balancer. That gives me some clearance to play with when positioning the engine. I accept that the accessory brackets will have to be custom and that I may need a spacer between crank bolt and balancer.
It also leads me down the path of a remote electric water pump since there's no way I'm using that monster LS4 pump... but one thing at a time.
Thanks again, appreciate it!
Old Nov 19, 2024 | 06:11 AM
fieroguru's Avatar
Here is the accessory drive I built for my original LS4 swap back in 2013. I cut up the stock water pump housing and relocated the coolant entrance/exit and thermostat to make room for the alternator and AC down low.
There is another swap with a LS4 that basically cut the LS4 housing down to just the runners connecting the 4 coolant ports on the engine and welded in some hose connections for an electric pump.
When I redid the swap from 2019-2023, I reworked that area. The clearance to the side frame rail was also tight, but it is angled giving me just enough room for a fabricated water pump setup to fit. I put all the accessories on the front of the engine to keep them hidden and help with weight bias. The Fieros have manual steering, so that was 1 less accessory I needed to fit.
Old Nov 20, 2024 | 10:23 AM
Bremer's Avatar
Thanks Fieroguru. Your new setup looks very slick. What is that water pump you are using?
I found your original build thread. Is there another one where the rework of the accessory drive is described?
Old Nov 20, 2024 | 08:43 PM
fieroguru's Avatar
The water pump was a custom designed unit. It uses an off the shelf water pump insert, but the housing is all custom.
Old Nov 21, 2024 | 09:38 AM
Bremer's Avatar
Very custom and very cool. Probably beyond the effort I want to go to, but good to see what can be done with focused effort and fabrication skill. Thank you for sharing!
