LS 5.3 engine dies while driving DBW Throttle
If you measured with that unplugged and got those results, there's your short as the code says. Have to chase that wiring from the TB Connector to the PCM and find it.
Long time ago I bolted a Transmission to an Engine and pinched all the wires in the Bell Housing. Had all kinds of odd codes so went investigating and found that. **** happens we've all done it.
did you get a chance to get a reading at F and G from yours, key on, engine off?
Thanks
Plug was connected to get some proper results.
If not connected i think the signal wires will be "floating"
Just curious, looking at your Post# 20. Your throttle position is at 7.1%, but I see your Long term fuel trims at -25%, and 21.0% on Bank 1 and 2, that would make the throttle % higher as the rpm is up. Do you have any lean or reach condition?
When i took this screen dump i think i just reset the long terms thats why it looks strange
With key on and engine of the blade is a bit more open than when running, not sure but look at it as a "crank" mode, when engine starts it will close.
With reach, and lean conditions, testing the TPS readings wont give you the correct information as those conditions cause the throttle to open more thn it would
Thanks
I really want to know. This isn't enough voltage or amperage for magnetic inductance so there's that.
I have two Degrees in Electronics and do that for my job, but clearly you're an expert above us here. I don't even know why the **** any us are commenting on this at this point. You have this figured out it seems.
So why isn't it fixed and running right yet?
I already told you what to do. Keep in mind you're the one with the vehicle problem, the codes literally tell you it. Two completely separate circuits shorted together. Anyone who knows electronics would see that and start looking at the wiring. I said that a few times. You just won't listen so we are wasting our time.
This is comical at this point tho, you're over there "I think this is normal because it's unplugged and the magical electric pixies are jumping from each unconnected wire.."
This is why in nature some animals eat their young. I'm out at this point the rest of you can handle this mess...
I am not an electrician, and do not have much knowledge about the subject, but I believe that I do understand a little bit of it. Now TP 1 and TP 2 are Potentiometer sensors. Read this below from GM DTC P2135 description:
The throttle position (TP) sensors 1 and 2 are potentiometer type sensors, each with the following three
circuits:
• A 5-volt reference circuit
• A low reference circuit
• A signal circuit
The TP sensors are used to determine the throttle plate angle for various engine management systems. The
control module provides each TP sensor a 5-volt reference circuit and a low reference circuit. The TP sensors
then provide the control module with signal voltage proportional to throttle plate movement. Both TP sensor
signal voltages are low at closed throttle and increase as the throttle opens. When the control module detects
that TP sensor 1 signal and the TP sensor 2 signals disagree, or signal voltages are outside the predetermined
range, this DTC sets.
Again with my limited knowledge on this, I came up with my conclusion based by looking at the TPS and TAC circuit diagram i had posted in previous post, and this Potentiometer drawing below. Maybe with your expertise on the subject you will explain to us. Thanks for your input.
