LS 5.3 engine dies while driving DBW Throttle
Old Jan 30, 2025 | 07:51 AM
  #61
bobcratch's Avatar
also, reading the trouble code description on the scanner (which could be wrong)
"TP1 sensor signal shorted to TP2 sensor signal"
the scanner is telling you that pin G is shorted to pin F somewhere (take this with a grain of salt, but also take it at face value for starters). Think about it - where is the voltage on pin G coming from? Since pin G has a pull down to ground, it should always be at 0V when nothing is plugged in to the tac module. if it's not, then its shorted to a something that is putting voltage on it, whether in the wiring or internal to the TAC module. And that's what the P2135 is telling you.
with the key off , measure the resistance between pins G and F. it should be very high. try wiggling the 8 pin connector around as well while you're measuring and see if anything changes. If you ever see a reading of less than 500 ohms or so, then there's your issue. If you never see a short there, also check pin G to pin H, and pin G to pin E. "Hey bob, why are you suggesting those pins in particular" great question, pins H and E are the 5V sources for the sensors. For pin G to have 5V on it is needs to be shorted to SOMETHING that is supplying voltage. Pin F is the most likely culprit based on the P2135, but the other two are possibilities as well.
my bet is that the issue is somewhere in the 8 pin connector going to the throttle body. I have seen issues there before where the crimps were either poorly done from the factory or just failed over time. I'm sure you can find a youtube video regarding how to remove the wires from that connector and inspect them.
Old Jan 30, 2025 | 08:55 AM
  #62
Tma120's Avatar
I will check for resistance between G&F, G&H, G&E with Key Off and report back. Will also check the 8 pin TPS connector, the pigtail used in the harness looks difference than the factory, the pins are kinda square and can see them at the top, the factory connect has the pins buried inside the plastic cover. I can even cut off the pigtail and try one of the factory connectors I have.
Old Jan 30, 2025 | 01:23 PM
  #63
Tma120's Avatar
Resistance with Key off:
- G & F = 0.440 MΩ
- G & H = 0.316 MΩ
- G & E = 0.315 MΩ
Old Jan 30, 2025 | 02:15 PM
  #64
the_merv's Avatar
Veteran: Air Force
Here's a simple way to isolate just the wiring.
Disconnect at the Throttle Body and the Connector at the Tac Module.
Use the meter do a continuity check between all this:
1 & G
​​​​​11 & F
1 & F
11 & G
See what you get there.
Old Jan 30, 2025 | 03:41 PM
  #65
Tma120's Avatar
1 & G
​​​​​11 & F
1 & F
11 & G
1 & G and 11&F Are good
Nothing between 1&F and 11&F
Old Jan 30, 2025 | 03:56 PM
  #66
Quito195's Avatar
Does anyone care that the ground on the block is obviously loose in the photo?
Maybe that bolt got tightened down after, but I’ve seen people bottom out bolts in that hole and have all kinds of cool problems.
Old Jan 30, 2025 | 04:28 PM
  #67
Tma120's Avatar
it’s def not loose, it got good ground too
Old Jan 30, 2025 | 06:20 PM
  #68
the_merv's Avatar
Veteran: Air Force
That rules out the wiring.
Something in the Module fried and is shorted together on them two circuits.
Old Jan 30, 2025 | 06:35 PM
  #69
Tma120's Avatar
I swapped out the TAC same results. It’s a used one, I can always go to the yard and try another one.
Old Jan 30, 2025 | 08:38 PM
  #70
Tma120's Avatar
Maybe these readings are correct?? Can someone with the same setup test for voltage on pins G/F to confirm.
I haven’t seen that issue since I replaced the Throttle body over a week ago now.
Old Jan 30, 2025 | 08:51 PM
  #71
the_merv's Avatar
Veteran: Air Force
Well, is the Code still there or gone?
Old Jan 30, 2025 | 09:09 PM
  #72
Tma120's Avatar
It’s gone. I haven’t seen the code since I replaced the TPS.
Old Jan 31, 2025 | 08:06 AM
  #73
the_merv's Avatar
Veteran: Air Force
Well, there's that.
I don't think any of us asked if the code was still there when you changed that TPS out, or the whole Throttle Body, however you did it. We were tracking on checking wiring given you had voltage in places you shouldn't have.
Maybe in the TPS itself the two individual circuits contacted somehow.
You still have 5v or close to it on G, D, or B?
​​​​​​​As mentioned F will have 5v given it's a pull-up circuit.
Old Jan 31, 2025 | 09:00 AM
  #74
Tma120's Avatar
Well, there's that.
Correct, in my Post #11 i had mentioned replacing the Trottle body, then I was schooled that the voltage was wrong etc. I havent seen the code yet since replacing the TPS, but again its not like the code use to come all the time, it was really intermittent. So i cant confirm that its fix.
Yes I still have 4.93v on both G/F.
Old Jan 31, 2025 | 09:13 AM
  #75
the_merv's Avatar
Veteran: Air Force
Per that Schematic you shouldn't have any voltage on G.
That's the mystery here apparently..
Old Jan 31, 2025 | 10:39 AM
  #76
Tma120's Avatar
Well I don't know what I shouldnt have there, but I know that both TP1 and TP2 must have similar readings, close to one another, and they output a certain voltage base on the throttle blade angle.
Now with the TPS connect unplugged, maybe it reading it as being fully opened? Maybe we’re barking at the wrong tree, I dont know, that why i asked if someone can get some readings on theirs and let us know.
Old Feb 1, 2025 | 08:27 AM
  #77
Tma120's Avatar
Read this below from our friend AI:
When the pigtail is unplugged from a DBW throttle body, Pin G (which is typically the Throttle Position Sensor (TPS) ground or signal return) could indeed show 5V (or near 5V), and here's why:
When the pigtail is unplugged, you may observe a floating voltage due to the circuit being incomplete. This is especially true if the TPS signal wire or other pins in the throttle body are still connected to the ECU or the throttle actuator control (TAC) module, which may cause the voltage to be pulled to 5V due to the way the system is designed.
In other words:
  • With the pigtail disconnected, the system is no longer able to pull ground or make a proper reference for the signal, so the voltage could read as 5V (since some components like the ECU may still be outputting voltage to the sensor circuits).
  • Pin G itself is meant to be a ground or signal return, so in normal operation with the pigtail connected, it should read 0V (ground) because it's part of the circuit. Without the pigtail, the ground circuit is not established, and you'll see an unusual voltage like 5V because of the floating signal.
If you're troubleshooting or working on wiring, it's critical to ensure the pigtail is securely connected to avoid floating voltages like this and ensure proper sensor feedback.
Old Feb 1, 2025 | 08:48 AM
  #78
the_merv's Avatar
Veteran: Air Force
AI has learned a GM TAC Module apparently..
It makes sense given what you're seeing, doesn't make sense given the schematic.
If all is well run it.
Old Feb 1, 2025 | 09:12 AM
  #79
Tma120's Avatar
it does actually make sense, considering that all measurements are fine with the pigtail connected to the Throttle body. Unless someone can challenge this with a better explanation that contradicts the above.
all run okay as it is. The DTC did not return since replacing the TPS, so we can call it resolved for now.
Old Feb 1, 2025 | 09:57 AM
  #80
01CamaroSSTx's Avatar
You're up and running so there's that. TPS is a component that can fail just like anything else.
