LM7 Lost OBD and fuel (I think!)
Engine was running (poorly and without pedalcontrol). I added an aftermarket fan controller (put the temp probe in the back head hole, wired into a blade with 12V on ignition and a terminal to 12V always hot, fan ground is a common frame ground. Now I have crank no start and the obd2 port has gone dead. The OBD port has 12V going to it, and the check engine light rigged into that system illuminates, but nothing on my scan tool. Doesn't even light up. I get a quick pulse of voltage to the fuel pump (less than a second coming to the wire) when I move the key to run, but nothing going to it on crank or staying on while in run.
It feels like a broken wire to me, but I'd love some extra brain power on this one. It was running! (poorly - but I found a vacuum leak and have the TAC module on the way (I've already replaced MAF and pedal position sensor, my TAC module is coming on Tuesday, I think) but it always started immediately. Now lots of crank, no start.
Or am I obsessing over fuel when it might be spark? I JUST DON'T KNOW
(which is why I have retired for the evening with a cold malted beverage. don't want to screw it up in a rage blindness)
The OBD port was a simple wiring issue (the 12V had come out of the back of the unattached for now port.)
I checked spark by putting a screwdriver into the plug boot (when it was unplugged from the plug) and got no spark to ground while cranking. I have unhooked the fans so that is out of the equation. I don't see any blown fuses.
Is it possibly a Crank Position Sensor?
1. I haven't had a chance to check all of the injectors (I am my only hands, so I have to rig a phone to record my multimeter while I crank) but here's what I found on Cyl 2 when I put the probes into it:
key on gives 6 .1 V, on crank it drops to 4.71 and seems to stay constant.
2. PCM is talking to OBD so it seems ok, right? Or are there other grounds that might be a problem? Should I check every pin marked GND on the schematic out of the PCM? (looks like blue 1, blue 24, blue 40, blue 64, blue 67, green 1, green 40)?
3. Still no spark when I pull the plug and crank it.
4. Showing the following codes:
P2135 (Throttle/Pedal Position Sensor / switch A/B Voltage Correlation)
P0120 ( Throttle / Pedal Position Sensor / Switch A Circuit)
P2135 a second time
P0120 a second time
Appreciate any insights.
All of the PCM grounds show 12 v when tested.
I get a cycling 1.2 volts on the PCM to coil connector (the PCM side) when I crank. But no spark on the plugs when I pull them and crank. I am much confused. Is there a ground for the coils separate from the ground in the harness to the coils? (both of those are showing good continuity to the negative post on the battery.
You also need to make sure you have large gauge ground wires from the engine to the body, body to frame, and frame to engine. The body, frame, and engine all need to be grounded together.
Any ideas?
I believe I may have found the problem. After a lot of checking and poking and proding, I think that the Crank Position Sensor wires lose continuity when they get plugged in. So if I checked them connector to ECM with the connector unhooked, I had continuity, but when I plugged it in, it was losing it. I finally ran a jumper so that I could check continuity with it plugged in and there wasn't any.
But I got it hooked up and showing continuity and then it cranked and burped and ran on what felt like 1 or 2 cyl before dying, but it threw an injector circuit open code (which is new) and I found out that while checking the injectors I broke a wire there.
Feels like I'm a lot closer than I was and that I was chasing a voltage drop that, while a problem, was not the primary root of all evil here.
