99 Trans Am corvette motor
I bought a 99 convertible 6 speed car without a motor and have my eye on an 99 LS-1 Corvette motor.
My question is what will the stumbling blocks be to dropping in an older vette motor? Ive seen some posts that say its a direct fit and others that say its a pain in the rear.
Isn't the Corvette drive by wire? You will need a cable throttle body, throttle cable bracket and inserts for the intake manifold. I've also used a threadsetter with epoxy.
https://streetmachinery.com/products...QXvVqztol4Jvvb
Corvette LS1 with LS Fbody Pilot Bearing, Fbody Cable Throttle Body with the Linkage Bracket, LS Fbody Accessories, Oil Pan, Engine Mounts..
Bolt up the Clutch you want and let it rip...
