Rough Idle(o2???) Paging Speartech!!!!!!!HELP
Thanks,
Remington
Do you have a working Check Engine light or ALDL connector on your conversion?
I had 2 sets. First set got fouled, installed the 2nd set, they got fouled. I gave up - certainly wasn't ready to experiment on another $$$ set of O2s. Via Atap I could see that the O2 readings were crap - they'd waiver all over the place even after warmup.
I'm sure the motor is running suboptimally in open loop mode, but it's fine for now.
Thanks,
Remington
1) Bad O2 sensors.
2) Exhaust system air leak (even a small one) allowing outside air to get to the O2 sensors.
3) Left and right O2 harness wires swapped.
If all else fails, get a scan tool on it somehow so that you can see what's happening.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
