how many teeth on sixspeed reluctor wheel
how many teeth does the reluctor on a 98 sixspeed have. after hearing that I would notice the differance if I had on I would like to fabricate something up
Originally Posted by LS1swap
I did mean the reluctor in the trans. I am just installing one for the pcm's sake not for any speedo
Originally Posted by Uk Robert
40 tooth reluctor wheel and pick-up are available from J.T.R(jags that run). About $170.00 I think. Their wheel bolts between propshaft flange and pinion flange(sandwiched between the 2) and saves taking `box apart.
the trans uses a reluctor wheel as well. at least from my understanding. a reluctor wheel is for anything that uses a magnetic pick up to keep track of rotating objects. the teeth disrupt the magnetic field. the cam and crank both use one as well. my speedo pick up is gear driven so it produces a voltage rather than just a pulse. so I can't use that. I have been told that having speed input to the PCM improves performance. I also need to figure at what point the pick up is located at. I am assuming on the output shaft of the trans.
