S10 LS1 header whoas
BTW, I didn't even know ANYONE made a header for an LS1 s-10, are the sanderson ones your only option for prebuilt?
I'm sure you know, but it'll all be worth it when it's finished.
maybe its possible to make some sort of spacer between the mount and the frame or the mount and the block to push it back towards the left side....might make it sit taller , dont know if you hgave room to go in tranny tunnel, but at least you clear the steering
Last edited by CMmotorsports; Dec 1, 2004 at 04:15 PM. Reason: wrong email address
Also have a few pics of clearance problems I ran into with the brake booster and the AC box. I have a 99+ motor with the fbody coilpacks on it. Maybe the truck packs would resolve some of these problems. I didn't try it I just modified around it. I used a brake booster off a Chevy Malibu being the S10 unit is the same one as the one on the fullsize truck. The S10 unit is 12" in diameter the Malibu one is 8", just enough room to make it fit right. Only mod to the booster is welding the S10 rod onto it. It bolted right to the S10 firewall with no issue. As for the AC box I just cut and filled it with plexiglass worked out real nice.
