Motor Mounts
Old Dec 13, 2004 | 12:41 PM
kdawgmfic's Avatar
Default Motor Mounts
I know I have seen it on here, a picture of the plates w/measurements needed to put early style motor mounts on these GenIII engines. For the life of me I cannot find it. Any one now the dimensions off hand?
Old Dec 13, 2004 | 01:08 PM
redaddiction's Avatar
Is this what you are looking for ?
Old Dec 13, 2004 | 01:29 PM
kdawgmfic's Avatar
Outstanding, I appreciate it man.
thanks
Old Dec 13, 2004 | 01:32 PM
No thanks needed I just saved them when someone else posted them up.
Old Dec 13, 2004 | 06:08 PM
81LS1Camaro's Avatar
The wrong hole is marked for countersinking the hole on the first mount, it should be the one just to the left of it. The guy that made the drawing didnt change it before he posted the pic. I am not sure about the other one (square one).
Old Dec 17, 2004 | 01:36 PM
67 Hot Rod Bird's Avatar
Default Motor mount diagrams
I'm new at this new gen motor stuff. What's the diff with the two motor mount plates? Is one the driver's side? If so which one is the driver's side.
Old Dec 17, 2004 | 01:56 PM
Scooter70's Avatar
You use one or the other and just make two of them. The reason that there are two drawings is that one positions the motor forward of the other by 1 3/4". Which one you use depends on where you want the motor to sit. The odd shaped one is what the S&P mount looks like. The rectangular one is what I used on my car to move the motor forward and make the tranny mount and shifter line up better.
(I thought that I had fixed the drawing so that the correct one was labeled as countersunk. I think you have an old version.)
-Matt
Old Dec 17, 2004 | 03:01 PM
when making the s&p style ones, do you counter sink them on opposite sides, or make them both the same, so one faces forward and one back?
Old Dec 17, 2004 | 03:44 PM
Scooter70's Avatar
You countersink them on opposite sides. The reason for the countersink is that the hole is directly under the SBC motor mount so it needs to be flush with the surface of the plate so that the mount can sit flat.
When everything's bolted down, it should look something like this:
Old Dec 18, 2004 | 10:58 AM
I just tried to use the s&p style mounts on my motor yesterday, the passenger side hits my a/c compressor on my camaro motor. Its not that big of deal to me, I am just going to move some things around a bit, but I thought others would like to know.
Old Dec 19, 2004 | 06:17 AM
kdawgmfic's Avatar
how far did the S&P style mounts set the engine back. i.e. how far did you have to move the trans crossmember back?
Old Dec 19, 2004 | 12:31 PM
I just tried them on my motor, I am going to move the motor mounts on the frame to put the engine where I want it.
Old Dec 19, 2004 | 09:15 PM
Default Did they fit?
Did the S&P mounts fit? I remember reading somewhere on this site that someone tried S&P mounts and the holes were about 1/4in. off. I'm thinking of trying to make my own to be sure the fit is good.
Old Dec 20, 2004 | 05:06 AM
they would of worked out pretty good but I have A/C and the passenger side mount hits my compressor
Old Jan 25, 2005 | 07:15 PM
I turned the crossmember around backwards and moved it back about 4 inches from the original location. This is with the driver's side motor mount in the stock location on the frame.
sorry I didnt reply to this sooner, I guess I missed your post
Old Jan 26, 2005 | 12:04 AM
flippincamaro's Avatar
i have s&p mounts they look good and fit good but wish the engine could of sat farther back like where the factory engine sat but oh well. they are nice
Old Jan 26, 2005 | 02:01 AM
renegademike928's Avatar
Default contact me about oil pans
i have ls-1 steel oil pans that i build for installation into my Porsches that i put them into, the alum pan doesnt weld very nice, e mail me directly, i dont get to read this all to often. mike@renegadehybrids.com
thanx
Mike Johnson
