computer harness conversion
Old Jan 19, 2005 | 09:44 PM
lmarino's Avatar
Default computer harness conversion
I am putting a 5.3 from an 01 suburban into my 75 blazer. I have the computer and engine, tranny harness. Is there any info available on what has to be done to hook up the harness to make it work? I understand the anti-theft has to be disabled in the computer. Are there modifications required to the harness as well?
Old Jan 20, 2005 | 04:50 AM
81LS1Camaro's Avatar
www.speartech.com
He's one of the sponsers
Old Jan 20, 2005 | 05:31 AM
badjuju342's Avatar
Deranged Rat Fink
If you plan on using the later transmission , you'll need to convert the VSS signal to a cable driven signal for your speedometer. Abbott Electronics makes just such a module.
Old Jan 20, 2005 | 09:30 PM
Gen3Benz's Avatar
Buying one from speartech is the least work.
You could get factory helms manuals and the 01 suburban underhood and powertrain harness and make them work easy.
mitchell on demand has good pcm pinouts but thats about it.
pcm pinouts help you trace all the stuff you want to dump....egr/air/fuel tank pressure/evap.
You can fool the vats(anti theft) out with a module, or program out with a tuner(edit,hp,flashscan).
I have an extra module it you want it, it came with the engine/trans I bought.
Here is my underhood harness
https://ls1tech.com/forums/conversions-swaps/99135-finished-my-underhood-wiring-harness.html
Old Jan 21, 2005 | 06:49 PM
lmarino's Avatar
Thanks for the tip, however since I have 4 wheel drive, the speedo is drven off the transfer case.
Old Jan 21, 2005 | 06:59 PM
lmarino's Avatar
What happens if you don't eliminate the stuff from the harness you don't need? If it isn't used anyway what will happen? When you "eliminate", don't you have to do something with the wire to fool the PCM? I was also told you have to relocate certain wires in the connector to make it work. As to the vats, I will probably have that programmed out of PCM. Thanks
Old Jan 21, 2005 | 11:46 PM
Gen3Benz's Avatar
Nothing happens if you dont remove the wiring.
It just looks better.
You dont have to fool the pcm if you delete emissions crap, it will just turn on the engine light.
It will not affect the operation of the engine/trans.
You can edit the certain emission codes so they dont turn on the light.
Relocate wires in which connector?
Old Jan 22, 2005 | 12:35 AM
Muffracing's Avatar
Post a pic when you get it going. I thought about putting a 6.0 in my '74, but the body is not very good. Are you running manifolds or headers?
Old Jan 23, 2005 | 12:34 PM
lmarino's Avatar
At the PCM, not sure which wires or function.
Old Jan 23, 2005 | 12:57 PM
lmarino's Avatar
Fortunately this has been a So. California vehicle, almost no rust. Although there is enough room to sleep under the hood of this thing, the motor wound up real tight between frame. I used camaro manifolds instead of headers. The manifolds fit better and produce less heat under hood. The EGR port was easy to hook up also. Although at this point I am uncertain whether or not to use it.
Old Jan 23, 2005 | 07:44 PM
Gen3Benz's Avatar
I just relocated the wires I didnt want into the garbage. disable the codes from turning on the engine light and you are fine.
