Removing Tranny Dowel Pins how to?
So what are your thoughts on removing one of those alingment pins. The pic was for a question but I solved the one question now my next is, well above.
The blue circle on the bellhousing with the X. I need it out.
Thanks,
-Matt
Thanks,
-Matt
I bought my motor and tranny separate and I had to remove the dowels from my bellhousing being I had both in the motor. I ended up lightly heating the bellhousing with a propane torch and locking a set of vice grips onto the dowel and just smacking the handles of the vice grips with a hammer until the dowel started to come loose. Then I just wiggled it out.
You should be able to just tap them out of the trans case since the holes are open to the back. The dowels are supposed to stay in the block but if thet are corroded pretty good they sometimes stick in the trans as yours did. I would probably use a little heat and stay away from a big ol' heavy hammer....you wouldn't want to break the case.
That looks very odd. Usually the dowels are in the block, not the bell. What tranny is that?
Andrew
Andrew
-Matt
Originally Posted by MrDude_1
on every GM trans ive seen, you can tap them from the back.... ?
Thanks guys!
-Matt
Originally Posted by ls1_chevelle
Correct but I do not want to bust off a piece of the bell housing. My initial instinct was curse the hell out of it and just bash that sum mo biatch out. Then I realized I kinda need that. I'll attack it with the propane torch with some tappage action tomorrow.
Thanks guys!
-Matt
Thanks guys!
-Matt
I just got an 8" socket extension and bashed that sob out. It wont break off the case. The structure of the bellhousing gives it strength. Atleast enough to knock those dowels out. I highly doubt you will have to hit it hard enough to break the case.
Much easier then I thought it would be. I thought to bastards were tight as hell in there. I just put some penetrating lube on it before I went to run my mom a coffee. Came home put the propane torch on it for a few seconds, tapped it out.
Thanks guys,
-Matt
Thanks guys,
-Matt
