Need some info..
Old Apr 5, 2005 | 02:10 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Need some info..
I am putting a LS1 in my 94 Z.I have already switched the fuel lines, rear end,K memeber,tranny,I am down to wiring.
What did you guys that have done this have to do.Do I have to send these harnesses off to get rewired? Any info would be greatly appreciated.
Dave
Old Apr 5, 2005 | 03:21 PM
MrDude_1's Avatar
are you trying to do a "just get it running" swap, or are you looking to have it 100% like OEM LS1 wireing? everything hooked up smog legal, or skipping the "extra" parts?
Old Apr 5, 2005 | 05:30 PM
sparky t/a's Avatar
PM speartech. talk to john and he'll let you know what you need to do.
Old Apr 5, 2005 | 09:34 PM
72ChevelleConv.LS1's Avatar
I took a truck harness and removed all the BS then pinned it to a camaro computer. after all it took, if you have the money, send it out. Not lots of fun. but lots of time.
Old Apr 6, 2005 | 07:10 PM
I would like for the gauges and blinkers to work.The car is pretty much a race car.No Ac or radio.It will be on the road every now and then to go play.
Dave
Old Apr 6, 2005 | 07:11 PM
Ok I will do.
Thanks
Dave
Old Apr 7, 2005 | 09:39 AM
MrDude_1's Avatar
Dave
in that case, you dont have to do a whole lot to get it working... just the basic power, and gauge wires... you can keep the stock harness and do it yourself without too much hassle..
Old Apr 8, 2005 | 04:17 PM
Here is what I was told.
I was told that I had to send in the ls1 engine harness.They said that they would make it work like a stand alone unit.They said I would still use the LT1 computer for gauges and would use the LS1 harness for the engine.They said that They would hjave to take security and something else out of the ls1 computer.This was going to cost 450 for the harness and 300 for what ever they had to do to the computer.FOR THE RECORD THIS INFO WAS NOT FROM SPEARTECH.(JOHN) It was from a compony out of San Antinio,TX.
What do you suggest?
Dave
Old Apr 8, 2005 | 06:11 PM
MrDude_1's Avatar
Dave
if you feel comfortable with doing so, id just wire the stock LS1 harness in itself.
the LS1 only needs a few power wires to the stock harness to run...
the gauges can be worked out one way or the other...
if you have the time and are willing to research it some, you could get it in and wired for less then $40..... counting zip ties, solder, heatshrink, a solder gun, ect....
Old Apr 10, 2005 | 11:07 PM
OK,
Guys thank you for your help.
I have contacted John at Speartech. He has been very helpful. Good thing I posted in here and were referred to him before I sent this harness over to this other company.His way is exactly what I was hoping to here.
Dave
Old Apr 10, 2005 | 11:08 PM
Thanks for you help.
Im just going to have it done so that everything will still work.
Im lazy.LOL
Dave
