FINALY LS1 3rd GEN HEADERS!!!
Thanks
justin
Justin
No problem
ill be at the f body gathering this year in atlanta. if anyone should have headers, i will see them up front and pay cash for them.
more than once f body motorsports took an order, charged a credit card, and the customer either waited forever for the product, or it never showed up.
this is not my personal experience, just what ive read on the internet from past experiences.
Justin
A guy on TG.O makes them!
Later
-Jeremy
The crossmember is for a LT1 T-56 so be sure you are running the right tranny to work with it because the LS1 and LT1 setup has different mount points. I already talked to that guy about making a setup for the LS1 tranny but didnt get to far.
The only difference is the front rotator mount, we weld a stud in it
instead of using a bolt because the bolt head will rub against the
LS1 T-56. Everything else is the same.
Steve
I would say the mounting points are the same, or they better be.. input shafts however are not
I would go with the headers but 1600$ of my colored money to get them shipped up here..
the pics i've compared to my 99 one, the case looks exactly the same with the mounting point in the same position.. the shifter on the 93-97s is more forward tho towards the engine
i guess steve spohn could be lyin to me.. i will find out soon enough.. maybe its something to do with the ls1 engine mounts and where it positions the tranny
bruce himself told me "you might have to notch the holes back a little, but its not bad"
i did so, and it fit right up....
only to get the exact same thing, but bright fuggin red (im not a fan of showing off crossmembers....) and no DS loop....
Justin
Thanx mr dude.. theres a load off my mind
If it is that much different I'll just modify this one
