LSx to Replace SBC - General Questions
Old Apr 14, 2005 | 12:42 AM
Builder's Avatar
Default LSx to Replace SBC - General Questions
Hi All,
I was wondering about the trans bell housing location. If an LSx is replacing an SBC, and I use adapter engine mounts (BTW they are solid mounts), do the LSx mounts move the engine forward, backward, up, down?
What is the relationship in size between an LSx and SBC? Is the SBC shorter?
Any manufacturer reccomendations regarding LSx adapters?
Thanks,
Old Apr 14, 2005 | 06:48 AM
Nine Ball's Avatar
LS1Tech Co-Founder
It depends on which brand or type of engine mounts you use. Some of them move the LSX forward, some move them backward.
SBC is longer than the LSX, due to it requiring the distributor behind the intake manifold.
Old Apr 14, 2005 | 08:31 AM
Stu Cool's Avatar
The LSx is about 1 inch shorter front to back and 1 inch wider than an SBC. The LS2 has a water pump that is a little shorter than the LS1. The ls2 water pump can be used on the LS1 but you may need to adjust the pulley to line up with your belt.
Pat
Old Apr 14, 2005 | 08:33 AM
Project GatTagO's Avatar
It is my understanding that the motor mount adapters from Street and Performance position the bellhousing in the same location as a 1st Gen SBC. I have no first hand experience, so you might want to give them a call to confirm.
Andrew
Old Apr 14, 2005 | 09:31 AM
Builder's Avatar
Pat
Andrew
Thanks, Nine. I am looking to stay as close as possible to the original location for the bell housing. The extra space will be a plus! It's going in a kit car.
Thanks, Pat. I have a clean slate to work with on the pulley and belt setup. No parts have been purchased yet. It would be great to end up with a crate LS7. We'll have to see what the price is... ... ... in August/September timeframe.
Andrew, page 64 of their catalog looks like the ticket. I will be giving them a call right now. Thank you.
I appreciate the replies!
Regards,
Old Apr 15, 2005 | 06:22 PM
digitalsolo's Avatar
I have a set of motor mount adapter plates from www.grannysspeedshop.com that are SUPPOSED to locate within 1/4" fore/aft of the SBC position (they use the standard 3 bolt SBC mounts). I'm putting the engine in a couple weeks, so I'll know then (and post here so we have a for sure answer).
Old Apr 15, 2005 | 08:22 PM
Builder's Avatar
Cool, that would be great. My chassis and engine won't be ready for many months. That would be good info.
Thanks,
Old Apr 17, 2005 | 02:52 PM
TJ's Avatar
TJ
https://ls1tech.com/forums/conversions-swaps/307636-trans-dapt-motor-mounts-suck.html
ive had some problems with the plates that use the old 3 bolt mounts.
they are trans dapt brand, but the street and performance, an off brand on ebay and the art morrison plates all look very similar.
Old Apr 17, 2005 | 03:07 PM
Builder's Avatar
Default TransDapt Not
Originally Posted by TJ
https://ls1tech.com/forums/showthread.php?t=307636
I was looking at the TransDapt website in the other window. Delete bookmark for motor mounts. Those others do look similar. Any comments on the other TransDapt mounting plates, like for a low-mount A/C. My setup will include an alternator, and low-mount A/C and dry sump.
