6.0L IROC almost done!
gm efi intake. edelbrock carb kit. z06 manifolds, EWP, 4th gen camaro fans and radiator, and a few other misc stuffs.
just need to get my alternator bracket done, and tidy a few wires up and out of the way.
went to the track.
threw a 4400 yank and a 9" i ran a best of
1.594
7.37
94.87mph
i was playing with shift points. this was only at 6700. ran out of time. mph kept climbing from a base of 93.3 at 6K to the 94 at 6.7K. allen at futral says this cam will go 7K, so i dont think 95-96mph is gonna be a problem.
http://img285.echo.cx/img285/3553/566694471gb.jpg
http://img265.echo.cx/img265/7607/566694679qq.jpg
http://img271.echo.cx/img271/9480/566694779kr.jpg
I'm very curious to see how yours runs with the carb. What tranny are you using? Mine's going into an 81z. Please keep us posted on your results!
Chros
th350 tranny with a 4000 yank.
im hoping it hauls the mail.
I MIGHT make it to the track sunday.
thanks for the comments.
What flexplate are you using for the th350? Is it the 98 one? I'll be going the th350 route as well and was wondering how you made it all fit.
the pills vary my idle greatly, which is part of the heavy idle of the cam.
my bud has a stock 02 motor and his pills dont change his idle a bit.
zedzag- im using the 2004 6.0 4L80e flywheel with the crank spacer milled down .157 thousandths for my application. i had to do this cause im running a yank from a th350, that was designed for a small block. the setup didnt work properly with the crank spacer like it was supposed to. i used it, and stock SHORT bolts for the 4L60e.
what a mess. im just glad it worked out.
grrrr.
thanks.
