3.8 camaro to ls-1 questions...please help!!!
i am doing a 3.8 to ls-1 conversion and i am having trouble removing the 3.8 i am trying to take it out thru the top. the intake hits the cowl and the oil pan needs one more inch to clear the k-memeber . should i remove the intake and try taking it out thru the top? or just unbolt the k-memeber and lift the car? please help......thanks in advance!!!!
Heehaa ya texas boys are always diff...... !
drop the K-member and trans ....thats it !
Check out Keith 3,8 to ls1 swap out.....his website also got a vid
http://www.dxsoftware.com/magnus/
...so i hope this helps!
If you get the same year LS1 harness, yep. Oh yeah and the LS1 gauge cluster too.
The wiring harness interfaces with the rest of the car via 2 connectors under the dash, and the 3 connectors on the passenger fenderwell.
The inj2 line is "empty" on the v6 chassis even though there's a label for it in the fuseblock (but no wire...) I just made a jumper, on the pcm side of the 3 fenderwell connectors. From the hot wire for the rear o2 sensors, to the inj2 feed.
I was pleasantly surprised when I did my swap. I expected to run into more.
