Fuel Question for LS1 in 94 S10
My plan on the fuel is to use the orignal fuel tank sending unit and replace the pump with a walbro 255 and use a corvette fuel filter/regulater. Is this possible or do I need to go a different route. I would like to keep the pump in the tank. Do I have to have a corvette fuel rail with my setup or will the f-body work? I have pics of the sending unit if needed. Thanks for any help that can be offered!!
You can use the F-body fuel rail and add the Corvette filter/regulator, or you can add the 97-98 Corvette fuel rail to the engine and skip the filter/regulator.
Either method creates the needed return line for your system. The filter/reg. is the cheaper route.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Be careful with the braided stainless stuff. I used the high-dollar Earl's braided on my Cutlass from front to back and wound up pulling it back off.
I park in an enclosed garage, and the fumes that came through the hose were killer. It took me a while to figure out it was fumes permeating the hose, I kept hunting for leaks, pressure checking hoses and fittings, etc.
It was the hose itself.
Replaced it all with steel and high pressure rubber hose and no more smell. The teflon lined braided might be OK, but it is even more expensive. Trending Topics
