Coolant fitting location
Old Jun 12, 2005 | 07:17 PM
bcrishon's Avatar
Default Coolant fitting location
Is there anywhere else people are putting the sensor for coolant temp other than on the drivers side head? It seem right next to the header, so I am unsure if I am getting a good reading. I am working with a 1999 LS1!! Thanks for the help!!
Old Jun 12, 2005 | 07:26 PM
SICMARO's Avatar
i have seen soom in the top of the water pump... there is a flat spot about an inch in diamiter..... but you will have to drill and tap it.
Old Jun 13, 2005 | 05:10 AM
GTS346's Avatar
Well thats where the factory sensor is and it works, so go with test and proven things, makes life easier.
Old Jun 13, 2005 | 09:12 AM
patrick_rodgers's Avatar
You can put the gauge sender in the passenger side head rear as well. That way, the computer gets its sender and you get yours.
Old Jun 13, 2005 | 01:33 PM
Rybar's Avatar
This site may help you out: http://www.xse.com/leres/ss/gaugepod.html
Old Jun 13, 2005 | 01:55 PM
redmist's Avatar
Default As Patrick says...
I'm using autometer guages, with the 12mm adaptor from Autometer it bolts right in to the passenger side head in the rear.
Old Jun 13, 2005 | 02:53 PM
gnx7's Avatar
I put a VDO sending unit in the water pump on the round casting boss next to the TB cam/arm. Drilled and tapped it and it works like a charm.
It is also a great place to bleed air out of your cooling system as it is the highest point in the motor.
Old Jun 13, 2005 | 04:32 PM
bcrishon's Avatar
You get a pretty accurate reading from there?
Old Jun 13, 2005 | 06:40 PM
DaleMX's Avatar
Mine is mounted where the optional engine heater is located. Here's a pic. http://www.circuitflex.com/WaterTemp.jpg
