Crank Re-Learn
Old Aug 7, 2005 | 06:18 PM
Frizzle Fry's Avatar
Default Crank Re-Learn
I'm getting closer to cranking it. Just wondering about the crank re-learn. How is it done w/o edit/tuning s/w? Is it something that's done before or after I get it running? Search did not turn up anything. Thanks
Old Aug 7, 2005 | 10:43 PM
01WS6/tamu's Avatar
Unless it sets the code for it not having been performed there is no need to do it. The pcm will not forget it after being powered off for extended periods of time. This is to the best of my knowledge so don't slaughter me if i'm off.
Old Aug 8, 2005 | 12:06 AM
I have a new PCM. I read that it must be done in this case.
Old Aug 8, 2005 | 07:43 AM
SUPRYZE's Avatar
If you replaced the PCM, then it will probably set a code for it. AFAIK, there is no other way then a bi-directional scantool/tuning software.
Old Aug 8, 2005 | 11:19 AM
But it will run?
Old Aug 8, 2005 | 11:24 AM
digitalsolo's Avatar
Originally Posted by Frizzle Fry
But it will run?
Having experience with GM L67s (Supercharged 6), which is a cousing to the LS1 sensor/PCM wise, I'd say it should run fine without it (actually, it has to, the engine must run before a CASE learn can happen). It may get some slight misfires (nothing major), and it's not likely to have even those. It will actually relearn on it's own over several hundered miles of driving, but the proper thing to do would be to take it to a dealer, and have them do the learn with a tech II. My dealer does it for free, I just tip the service guy-
Old Aug 8, 2005 | 12:16 PM
Thank you. I wasn't sure if it learned during cranking or running.
Old Aug 8, 2005 | 01:45 PM
MrDude_1's Avatar
it learns while running..
BTW, HPtuners can also do it.
