My LS1/T56 swap into '68 Chevy C-10 stepside
Old 01-30-2006, 05:09 PM
  #61
shifty`'s Avatar
peregrine, admittedly that sounds great but I plan on using in-tank fuel pump, so baffling is really something that I think is important to me! I know with my driving - my main fear is "what if" - doesn't aluminum rip, tear or crack on impack with things? Being in the rear of the truck, seems it would be pretty easy to get smacked into...i'd totally be open to spending that rather than $1100 for the ECE setup w/pump. :\ It's such a tough choice for me. I know if it came down to it, resale on that aluminum cell would probably be just as high as purchase price, so ... if it didn't work out, you could always turn around and sell it again
Originally Posted by blazerboy72
I pick my motor up next tuesday for my 71 2wd blazer, I may need some advice once i get started.
I got your back. A lot of info is in this thread already - I highly recommend reading up on all the links in here. I am gonna link up a post over at the truck forum which explains how to make your own engine mounts too as soon as I get the computer with that info up and going again
Originally Posted by 67RSCamaroVette
For your Xmember problem, you could always get a Competition Engineering mount like I did, and mount that inside some C-channel, and simply line up the holes you drill in the C-channel to bolt it to the frame. I didnt notice if your frame was boxed or not, but if it isnt, it would not only add more strength, it'd work great. Here's what i mean...
Thanks for the advice, olly. I ended up buying the ECE xmember. It arrived and was a bear to shove in place. I should have really smoothed out the inside of my framerails first. I can't tell if it's sitting in place right or if it's straight, so I got fed up this weekend and decided to rip out the column and prep the cab up for removal I'm going to go ahead and take the cab off, clean up the framerails completely (properly, the PO of this truck didn't do that) and slide it back in. I'm almost certain this ECE bracket is offset enough to mount in the stock holes... Overall, it's a nice piece they make. Almost everything I've bought from them has been top notch!
EDIT: I realize, in retrospect, that the smartest thing I could have done to get a new tranny xmember in WITHOUT any cutting/grinding/sanding and without removing the cab, would have been to use http://www.classicperform.com's tranny crossmember for 60-72 pickups (part# CP9427). This only requires bolts in the bottom of the framerail to go in and gives excellent clearance.
Ah, so the project drags out for yet another week!
PS - in case you want more info about FuelCellGuy's product, please click here for more info:
http://67-72chevytrucks.com/vboard/s...49&postcount=5
That should answer any questions you might have.
Old 01-30-2006, 10:10 PM
  #62
67RSCamaroVette's Avatar
awesome.. I too like to take the body off the frame to inspect for any rust, replace bushings, and its much easier to clean and assemble suspension and drivetrain components when it's apart (as many times as it takes , mine's been off 4 times, and still needs to be removed once more..). Good luck with the xmember..
olly
Old 01-31-2006, 03:07 PM
  #63
peregrine's Avatar
So do you know for a fact that FCG's tank isn't baffled? I am curious. A piece of info I would like to file for future reference.
Thanks
Old 02-05-2006, 09:07 PM
  #64
shifty`'s Avatar
His tank is baffled, it comes with the sending unit and optionally you can get it with the fuel pump already installed. It's definitely a great deal. I've been PM'ing him back and forth at the truck forum, I've decided I'm going to go with him instead of ECE - I can get his 18GAL setup with the pump for about 1/3 less than what I would pay for ECE's stuff. Turnaround time is gonna kill me (want to be done by May) but ... you gotta live with it!!
Now comes the fun part! Trying to find some HEADERS that are a direct bolt and and won't give me a problem. I've heard you can modify vette headers but ... I'd pay an extra hundred or two just to find something that will be a direct bolt in with O² bungs....
Old 02-07-2006, 11:05 PM
  #65
shifty`'s Avatar
Originally Posted by peregrine
I assumed FCG's tanks were baffled. Here is what he said to me in a PM 11/05
Yeah, I sent some PM's back and forth to him. They are baffled, I've seen pictures in mid-construction and got full details. You can't beat the price, with the fuel pump, hardware, sending unit and all the other stuff it comes with, it's still $100 less than the ECE setup with no fuel pump!
I'm going with the 18gal and the Walbro in-tank pump setup. Should be here in a month if all goes well. Gonna Line-X the outside of it.
As for progress, not much new, still haven't had the time and motivation to take the cab off, finish the tranny xmember bolt-up and get the drivetrain done. I'd planned on getting the PS hoses done, but I'm budgeting until income tax return comes back. Still trying to pay off the rest of the engine too :\
Anyways, here are some pics of the shifter installed
Attached Thumbnails My LS1/T56 swap into '68 Chevy C-10 stepside-shiftery1.jpg   My LS1/T56 swap into '68 Chevy C-10 stepside-shiftery2.jpg
Old 02-08-2006, 09:25 AM
  #66
peregrine's Avatar
That's good to know. I will go with him too when I start. I have so much going on here it will be a while before I can even think about my truck. New job, new side business, yadda, yadda. You know the drill. For now I live vicariously through you.
Old 02-11-2006, 11:32 AM
  #67
IOwnCalculus's Avatar
That shifter placement is part of why if I ever blow up my 4L60E and decide to go with a stick, I'll go with a TKO (which, as far as I know, has several options on it for where to put the shifter). That, and the fact that everything I've heard says that the gear ratio range from first to sixth means that depending on your rear, either first won't be usable due to lack of traction, or sixth will be too tall.
For what it's worth, I stumbled across another LS1/4L60E into a '72 C10 at Firebird last night...looked like a very nice install in a nicely restored truck. Ran well too, ticked off a 13.7 (drag radials and a positraction...I was running 14.2 - 14.4 with Yokohama Avid S/Ts and a one-tire fryer).
Old 02-19-2006, 06:10 PM
  #68
shifty`'s Avatar
There is a lot of good info on this swap including parts numbers, info on things you will need to retrofit (but it's referencing a 68 Camaro) at this site, which I stumbled upon by accident:
http://hotrodlane.cc/Streetstories/6...ls1camaro1.htm
It's multiple pages of information and is a great swap write-up. There is information on the engine itself, mods like adding a manual temp gauge, etc.
Now, I'm not entirely sure about the TKO tranny you're talking about, but I did notice this tidbit of info at that site:
The T-56 6-Speed is 3 1/2” longer than the muncie. The JTR Book by Mike Knell has the product to adapt the T-56 to a manual speedometer drive. Borg Warner or Visalia offers a shorter tail housing for the T-56. This tail housing will move the shifter location forward 2 3/8"
So it's not only possible to use a manual speedometer, but it's also possible to pop on a diff't tailhousing that will give you almost 3" of forward movement of the shifter itself.
I admit, it's quite uneappealing to have the shifter that far back, but right now I'm more concerned about getting it up and running than dealing with the shifter location
Old 02-23-2006, 09:00 AM
  #69
Heh, I know exactly what you mean That's a bridge I won't have to cross until that 4L60E screams for mercy, though.
Old 02-25-2006, 10:09 AM
  #70
Terry'sToy's Avatar
Has anyone put a set of longtubes on one of our trucks??
I have a set of flowtechs and they will really need some work to fit well.
Any help/info would be great.
Thanks
Old 02-25-2006, 10:51 PM
  #71
shifty`'s Avatar
huge breakthrough - the stock WS6 headers (with cats and O² sensors) fit with only minor grinding on a small part of the passengers side. i'd been told by two people that the stock manifold/cat would not fit at all so don't bother, but they appear to be doing just fine. i am now saving at least $700 on parts by not buying new ones
i've noticed in my case that the driver's side pre-cat O² bung interferes with my brake lines a tad, so I might need to relocate or bend the lines a bit. i wanted to upgrade the brake system anyways when i lowered the truck.
Here are pictures:
The little rusty bit sticking through the heat flange on the header is what needs to be ground down:
http://satellitehead.com/uploads/ls1headers001.jpg
this is a picture of the fitment of the driver side manifold/cat w/o the O² bungs. word of advice: you'll be doing yourself a favor to put this in from underneath the truck and the fitment might not be this good if you're using an auto tranny with column shift, i obviously don't have that burden :
http://satellitehead.com/uploads/ls1headers002.jpg
a picture of the fitment in relation to the brake lines:
http://satellitehead.com/uploads/ls1headers003.jpg
a closeup showing proximity to brake lines. with the pre-cat O² bung installed it stuffs between the two brake lines. i personally want to keep my pre-cat installed and don't care so much about the post-cat, but will use it! i'm not sure if i'll even need to reprogram the PCM using all of this stuff...i guess we'll see. meanwhile, gonna post in the main forum to see what is safe to grind down on that passenger side manifold
http://satellitehead.com/uploads/ls1headers004.jpg
i wasn't even going to bother test fitting them - but i was having problems breaking the cat and manifold apart, so i figured, man this is a pain, i should at least TRY To see why it wont fit!"
this goes to show you - TAKE EVERYTHING WITH A GRAIN OF SALT. question everything anyone tells you when you're doing a swap like this or hell - life in general.
Old 02-26-2006, 02:08 AM
  #72
Terry'sToy's Avatar
Thanks for the info and pics.
I had those on the truck for a month or so. I didn't use the cats so I just welded up some pipe w/flowmasters. Sounded great. I've now decided to do a frame off resto, so I bought some flowtech longtubes for a LS1 camaro, and I'm making them fit. I had to notch the frame in a couple of spots as well as the top of both motor mounts. I also had to get the last tube on the drivers side cut and moved a bit to clear the lower control arm.
All is going well though. The truck was a blast to drive for that short time.
I should be back on the road in a couple of months.
Old 02-26-2006, 08:21 AM
  #73
68shortstep's Avatar
terrys toy......... since were on this topic....... can you post some pics up of how they look and fit?
shifty.......... your truck is going together nicely........ you're a big help.. what are you running as far as brakes and suspension now? in hinesight whould you of pulled the cab off?
Old 02-26-2006, 09:47 AM
  #74
Terry'sToy's Avatar
68, I have to go do a trans swap on my buddies stang today, but I will try and get some pics up. My wife took some yesterday. I'll try and get some shots of where I had to modify things. If I wait until tomorrow, I should have the drivers side header back and I can show how that was modified also.
Terry
Old 02-26-2006, 01:58 PM
  #75
shifty`'s Avatar
brakes are still non-power drums on all four. that will change once swap is complete - brakes and suspension are being done @ the same time, I hope. i'm bagging the entire truck.
in hindsight, i would have pulled the cab off, but ONLY because i'm using the T56. if I would have done the 4l60e, i probably would not have yanked off the cab. and for the record, i would have first pulled the engine, then taken off the front clip, then popped off the cab, then removed teh tranny and its xmember, then started the install. would have been easier to work on the tranny hump w/the cab out.
i also would have sent the tranny to Keisler automotive in TN to have the tranny redoce for $500 or whatever to have the shifter moved to the forward mount slot. i couldn't have used the Pro 5.0 shifter if I did that, which sucks, but it's a small sacrifice for the convenience of using teh stock bench or being able to use a 40/20/40 bench without making a custom shifter.
Old 02-26-2006, 02:06 PM
  #76
350SS's Avatar
Good to hear that you got things to fit. I can't tell you how true this is. Everyone I talked w/ said a 6.0L/4L80E combo wouldn't fit into a 72 chevelle w/o cutting the floor pan to **** and modifying an f-body oil pan. Sometimes all it takes is some "creative thinking" or like you said, just at least TRY.
Old 02-26-2006, 03:10 PM
  #77
shifty`'s Avatar
Okay, passenger side is a no-go. More info here:
https://ls1tech.com/forums/showthrea...80#post4322580
I went ahead and hacked, but I'm seeing that even if I removed or bent the heat shroud on the passenger side, I would still have clearance issues with the flange - I could probably do some creative grinding and MAKE it fit, but I'm going to give the '98 passenger exh manif a shot before calling it a loss. Still can't get over how much clearance is available on the driver side!
Old 02-26-2006, 11:27 PM
  #78
350SS's Avatar
guess I spoke too soon
Old 02-27-2006, 12:46 PM
  #79
shifty`'s Avatar
I could make it work, I'm assuming it's no more work than the 'vette manifold install modifications (which nobody has been able to describe yet )
I'm looking into purchasing the '98 manifolds listed in another thread. I'm going to give them a shot before giving up :thumbs:
I'd rather pay $30 now for stock ones that might work than $500 now for ones that will totally work.
Old 03-10-2006, 09:22 PM
  #80
shifty`'s Avatar
Good news - got the '98 manifolds today (thanks ashade98). Still haven't managed to get all the damned packing peanuts out of the tubes but I digress. Damned UPS busted the package (hate those bastards).
Ah, but good news. The stock '98 manifolds fit like a champ with plenty of clearance from what I can tell.
Attached Thumbnails My LS1/T56 swap into '68 Chevy C-10 stepside-98manifolds-002.jpg   My LS1/T56 swap into '68 Chevy C-10 stepside-98manifolds-004.jpg   My LS1/T56 swap into '68 Chevy C-10 stepside-98manifolds-005.jpg   My LS1/T56 swap into '68 Chevy C-10 stepside-98manifolds-006.jpg
Quick Reply: My LS1/T56 swap into '68 Chevy C-10 stepside
