Corvette engine to F-body specs help..
Some things I know are different:
Oilpan (duh), oilpump pickup, and windage tray
Accessories (including AC compressor & Harmonic Balancer)
Throttlebody should be electronic on C5, cable on f-body.
Harness is slightly different (because of throttlebody at a minimum)
Exhaust manifolds (obviously) but bolt pattern is standard.
Reasonably certain the camshaft is different (like different duration / lift specs, not fit function type different)
The crank & such should be the same, no real differences there. Flywheel / flexplate may be different, not sure on that.
If you do buy a complete 'vette motor with accessories and don't need the C5 accessories, PM me. I'd be interested in all of them (AC, Alt, PS, balancer, everything) if they're available.
'Dreamin'
https://ls1tech.com/forums/showthrea...el+rail+return
Personally, I don't see much benefit from running a return type system. Maybe somebody else can shed some light on the why that is preferred (if it is preferred).
And thanks for keeping me in mind for the accessories if you buy a vette motor with access.
'Dreamin'
I've been told the cams were the same as the f-body for the same years.
Where did you get this information?
According to Will Handzel's book "How to Build High-Performance LS1/LS6 V-8's" the cams for certain years are the same. But for other years, they're different.
On page 46 there's a chart that list camshaft specifications.
The '01-'02 Vette & F-body use the same cam, PN 12561721, with 198/207 duration, and .467"/.479" lift on a 116 degree lobe centerline. Interestingly, the '01-'04 LQ4 & LQ9's (maybe later) also use that same camshaft.
All other years of vette and f-body uses slightly different camshafts. The duration, lift, and lobe separation numbers are very similar, but not exactly the same cam.
For example:
'98 f-body cam is PN 12557812, and is 198/209 .500"/.500" on 119.5 LSA.
'98 Vette cam is PN 12554710, and is 199/207 .472"/.479" on a 117 LSA.
Very similar, but not the exactly the same.
'Dreamin'
'Dreamin'
So, you've got my curiosity...Whatcha buildin'?
'Dreamin'
So instead I went out and bought a Pontiac Fiero (I know some of you are laughing....stop it) I ordered up the kit from V8Archie.com (excellent customer service and support) and now I'm just plannig all the little stuff like fuel, exhaust, pcm....the gas tank on the Fiero is under the center console and the engine is about a foot behind your head. Sounds like fun to me! Pics will be posted after I receive the kit and start disassembly. Went from a $20-25k expected cost to a $12-15k expected cost, including the price of the car. Think 400 rwhp in a 2800 pound car will get me mid 11s? That's what I'm shooting for. Oh, back on post topic, the kit calls for an LS1 with an f-body oil pan, early C5 exhaust manifolds and fuel rail as well as C5 harmonic dampner. I've only found C5 LS1s, so i'm trying to see how to get it in spec for what I need (no electronic trottle either). !rambling
a rear mount app like that is one of the few times i would consider running the electric throttlebody... a couple wires is easier and more accurate to run then a cable/linkage setup around the car......
post up some pics when you get into it
