Crankshaft Position Sensor Location?
My Check Engine Light Comes On And Reads..crankshaft Position Sensor Low Circut...what May This Be? Were Is This Located For 99 Ls1? Thnx most likely...unless somewhere you got a pinched/cut wire......
no you shouldn't hurt anything (its just a magnet).....if the sensor were "that bad" the car wouldn't run.....
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
This sets the timming on the LS1- but only the GM tech two scaner can do this. No other scaner I know of can.
