flush oil fill cap????
I would like to find an oil filler cap that fits directly into the valve cover. I would like to make my own engine covers and dont want to have a hole for it to come through like the stock ones do.
Theres a member over at pro-touring.com that was building custom LSX valve covers that were a flush mount threaded cap. Looked very slick. But it was just around 500 bucks for 2 fabbed covers.
-Matt
-Matt
Originally Posted by vodas00ss
im not 100% sure, but that sounds like you might need to get with a manufacturer of frc's and tell them what you want, never seen an frc without a hole for a filler neck and cap.
ill be making my own frcs out of aluminum
Originally Posted by jimmyp
you have done this?? Your saying the cap screws directly into the valve cover?
ive seen some cars/trucks that didnt have a stack.
valve cover, with the oil cap screwed right in.
it has the same channel, the stack just has a tab to lock it in place so you dont bust it loose while removing the oil cap.
good luck.
