Fuel lines?
Old Oct 27, 2005 | 02:55 AM
1fine69's Avatar
Default Fuel lines?
I know this has been covered before, but I can't seem to find it right now...
98 LS1 is in the car, and I'm ready to run the fuel lines for the supply. This is my plan:
Run a Tanks, Inc. in-tank pump with 255-lph Warlbro pump into either
A) -6AN fuel line to the quick-disconnect fitting on the fuel rail, OR
B) Jeg's 3/8 fuel line to the fuel rail
I will use my stock fuel line as a return, and retain the original sending unit so i can keep a fuel level guage.
Before I start ordering parts, could someone check me and make sure I'm not missing anything somewhere...will the Jeg's lines work just fine, 'cus they'd save some money?...I have a tube bender, so that's no problem.
I don't need ANOTHER in-line fuel pump, do I? Since this is a '98 F-body fuel rail, I DO NOT need the vette fpr/filter, correct? I do plan on running a fuel filter, of course, but I don't need to get that piece...right? I'm kinda a newb to fuel injection, so thanks for being kind and patient.
Old Oct 27, 2005 | 04:22 AM
67pete's Avatar
I have a '99 LS1 in my '67 Chevy II and in trying to keep the stock look I found adaptors from Lingenfelter for the supply and vapor return quick connect lines.These connect to NPT threads which I will then connect to my 3/8" aluminum tubing.
It all depends on what you want the end result to look like!
Old Oct 27, 2005 | 05:12 AM
Schitzo's Avatar
I am also using the tanks inc setup.You will need the corvette fuel filter/regulator if you use the f-body rail (97-98 corvette rails have the regulator on them)
Old Oct 27, 2005 | 01:22 PM
1fine69's Avatar
Are you sure? I've had a few people tell me I don't need the Corvette filter/regulator since it is a 98 Camaro fuel rail...?
Just making sure.
Old Oct 27, 2005 | 03:35 PM
ls1_chevelle's Avatar
Your check list is pretty good. If you have to run the vette regulator.... Just put it near the tank and prevent having to run a long *** return line.
-Matt
Old Oct 27, 2005 | 04:50 PM
Steve68's Avatar
I too am wondering about this, I want to run a tank from Rick's Hot Rods, a 3/8 line and I have a 98 F body fuel rail, do I need a return line??? or the Vette FPR/ filter, I was going to run a F body filter, Rybar might know, he has a Ricks tank,
Old Oct 27, 2005 | 05:08 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
A 98 Camaro fuel rail is no different than a 99-02 Camaro fuel rail. You will need an external fuel pressure regulator (either the Corvette filter/regulator or an aftermarket). The only LS1 factory application that had a built in fuel pressure regulator was the 97-98 Corvette. This is easily identified by the dual lines on the fuel rail (1 feed, 1 return).
Just making sure.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Oct 27, 2005 | 07:21 PM
1fine69's Avatar
Thank you for the help! You guys are lifesavers...
