NEED IDEA FOR PICKUP TUBE! help!
It's about an inch above the bottom of the sump. I want to do something like this...
any help would be good.
olly
For my pickup tube, I heated it up with a torch and straightened out the kinks and curves for added length. You must have the pickup with the screen on it. Otherwise you will restrict the flow of oil and hurt your motor if you just have the tube itself with a screen on the end. You will blow it up. Not enough oil can flow through a screen with an area as small as the tube itself. That is why they come with a large pickup and screen. More area for the oil to flow through the screen.
As far as the baffle goes, you will have to cut it as much as you cut the pan.
Hope this helps.
olly
olly
Am I correct in assuming that you're calling the windage tray (chunk of metal that bolts to the main studs) a baffle?
If so, your best bets are either a good GM dealer (if you can find somebody who will sell it to you at a good price (Personally I like Team Chevrolet in Nebraska for internet orders)) or a good junkyard / salvage yard / whatever the PC term for those are these days. There is a FAQ that has GM part numbers in it (check the top of the Conversions & Hybrids page), if that helps any.
If not, then you're probably still looking at the same two sources, just I'm not sure if that individual part is sold. You might have to pick up a new (or used) pan to steal it from. Or you could just make up a new one.
'JustDreamin'
olly
