wiring harness........
Old Feb 7, 2002 | 03:01 PM
Tony@AirRideTech's Avatar
Default wiring harness........
Do any of the aftermarket wiring harnesses for the LS-1's come with the serial port to accept the LS-1 edit?
Tony....
Old Feb 7, 2002 | 06:28 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: wiring harness........
Not makin' a sales pitch, but ours certainly do! <img src="gr_stretch.gif" border="0">
In all honesty, since LS1_edit communicates thru the factory diagnostic link connector, you should be ok with any harness. Even the mass produced, corner cutting harness makers include that port, I believe.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Feb 7, 2002 | 08:48 PM
John B's Avatar
Moderator
Tony, I had Speartech rewire my harness and it came out great. I wish I could say the same for the people that have e-mailed me with harness problems created by "other" suppliers! Well worth it and half the cost of a new harness (which isn't necessary!)
Old Feb 7, 2002 | 09:14 PM
LS1 ZR2's Avatar
Everyone does not add the communication link, but they should.
Old Feb 8, 2002 | 08:38 AM
John@Speartech.
Now do you make your own harness or are you remapping the OEM harness? Would you have any idea if any provisions I will need to look for in a harness when using the T-56 also. I had read up about the CAGs, and I am asuming that I am going to need the skip shift along with the harness? John just to try to get you up to speed, I am going to run a pro-charger on this cahuna at about 7-8psi.... and I have been informed that the LS1-edit is the easiest way to re-map your timing and fuel curves for running 50# injectors and knock the timing down so the KR doesnt kick in. I was originally looking at the painless unit along with thei 18 circuit harness for the rest of the car if you have any other suggestions or ideas let me know.
Tony....
Old Feb 8, 2002 | 10:17 AM
Mike TexaSS's Avatar
8 Sec Tuner
T
8 Sec Tuner
T
Old Feb 8, 2002 | 08:20 PM
MADSCI's Avatar
9-Second Club
The painless harness comes with the connector to use a snap-on scanner or auto tap so i would say this should work for you with no problems!
Old Feb 9, 2002 | 12:16 AM
Speartech's Avatar
[quote]Originally posted by Tony@AirRideTech:
<strong>John@Speartech.
Tony....</strong><hr></blockquote>
Tony,
We do both; brand new stand alone harnesses or factory harness reworks. The rework is of course cheaper, while the new harness allows you to define where you want to mount the PCM in your vehicle. If you want to mount the PCM in the trunk, just provide the measurments and we will build to your specs.
Most people don't want the CAGS, so we usually leave it out of the harness, and you never need to be bothered with it. You would of course have the diagnostic port included with either harness option, so you could take advantage of LS1_edit as soon as you hook up the harness.
We don't make vehicle harnesses, so you would still need to source your 18 circuit harness somewhere else.
__________________
www.speartech.com
Old Feb 11, 2002 | 10:37 AM
I appreciate all of your input..... and I might be getting with you later John to do a custom harness once I determine placment of the ECU.
Tony....
