computer reprogram???
Old Apr 17, 2002 | 08:44 PM
502454's Avatar
Default computer reprogram???
This may not be the right place for this but here goes anyway. I am ready to start wiring the LS1/T56. I plan to use a Painless Wiring Harness for my 98 LS1 computer, do I still need to have the computer reprogramed (they say you don't)? What extra stuff can I remove from the motor (EGR / second cat o2 sensors / etc.) It is going in a 70 Camaro and I an also going to change the fuel rail to a corvette's with a return line to the tank.
Thanks,
TOM
Old Apr 17, 2002 | 10:33 PM
John B's Avatar
Moderator
Default Re: computer reprogram???
You can run the car with zero changes to the PCM but it will throw codes. I did nothing to mine when I fired it up. If you plan on any level of mods, I would get the LS1_Edit since this would take the place of even a MAFT.
Old Apr 18, 2002 | 03:52 PM
blackhawk2000's Avatar
97 C5 uses a return system. Just use the OEM fuel rail.
Old Apr 19, 2002 | 12:02 AM
502454's Avatar
OK so no mod to get running, that sounds good at least I will be able to drive it. What about the back o2 sensors are they eliminated? Can I remove the EGR? Is there anything else that can be removed?
The 97 C5 has a return in the fuel rail is that the only year?
Thanks for your help,
TOM
Old Apr 19, 2002 | 12:06 AM
John B's Avatar
Moderator
You can eliminate the EGR (I did, it just throws a code) and the rear O2's (again, it'll throw a code). The '97 & '98 C5 use the same fuel rail.
Old Jun 7, 2005 | 07:38 AM
Joe Nova's Avatar
John B Where can I buy the LS1 Edit?
Old Jun 7, 2005 | 03:51 PM
crainholio's Avatar
You can get it at http://www.carput... oh wait, I'm not John B.
Old Jun 8, 2005 | 09:44 AM
Chris @ Speed Inc.'s Avatar
if wont you can send us your computer and we can remove all that stuff and do a basic tune for $150
