Conversion folks please list your conversion in here
Old Nov 4, 2007 | 12:20 AM
  #641
martinsw's Avatar
1) 1979 corvette 350/TH350
2) 2000 vette engine, T56 from 01 camaro, PCM from 99 Firebird
some posts on corvette forum,
started conversion Nov 2005, running again Mar 2007, CA smog legal July 2007, sanding for new paint job now....it will never be done....
Old Nov 4, 2007 | 04:47 PM
  #642
mx5.7's Avatar
94 Miata
Not an LSx, but wish that I would have went that route
406ci SBC
T56 out of 99 WS6 using mcloed spacer and clutch
7.5" Ford IRS rear out of 91 T-Bird
I came here mainly for info on the T56, but quickly realized that LS1 tech is a wealth of knowledge.
Attached Thumbnails Conversion folks please list your conversion in here-680654_79_full.jpg   Conversion folks please list your conversion in here-680654_75_full.jpg
Old Nov 5, 2007 | 10:08 AM
  #643
TXjeepTJ's Avatar
ls1 jeep wrangler, everything is done except for the coolant bottle and need of wiring loom lol
Old Nov 8, 2007 | 11:57 AM
  #644
Frnichols's Avatar
Default How do you upload photos?
How do you upload photos in a post. I tried several times to no avail. Oh, nice conversion.
Old Nov 9, 2007 | 04:55 PM
  #645
Ravant's Avatar
Well - it's still in the planning/parts-gathering stage, but... here goes nothing.
Vehicle: 1985 Pontiac Fiero 2m4 (3-speed auto... ugh.) Notchback, she's still stock and in need of restoration (interior and exterior.)
Engine: LS1
Transmission: M6 (GM F40, RPO: MU9)
Supporting changes to the rest of the vehicle: Far too many to list.
As for pictures:
This is her the day I bought her. $675... needs some TLC, but it's all rust free.
And here's a picture of her current home.
She's now eagerly awaiting the engine swap, because this engine isn't cutting it anymore.
Old Nov 11, 2007 | 06:24 PM
  #646
Dave in Dallas's Avatar
69 Cutlass Convertale currently off the frame with a 99 Firebird LS1 to go in it. Working on frame mounts to accept LS1 motor mounts. Hope to afford twin-screw supercharger on stock motor. Have a lot to learn...
Old Nov 18, 2007 | 09:28 PM
  #647
55ChevLS1's Avatar
Thumbs up
55 Chevy 2 dr sedan
04 GTO LS1 w/4L60E
Previous frame off restoration, now I'm doing the engine upgrade
Just got the engine installed 2 weeks ago.. S&P front pulleys, wiring
harness, headers, Rock Valley gas tank w/fuel pump, Vintage air A/C
670 P/S and Ididit column, Classic Rod guages.
Old Nov 19, 2007 | 06:33 PM
  #648
ACONLP's Avatar
Originally Posted by 55ChevLS1
55 Chevy 2 dr sedan
04 GTO LS1 w/4L60E
hey hows it going. the rock valley tank, how much did that run and do you have a number for them.
Old Nov 25, 2007 | 11:51 PM
  #649
vettezuki's Avatar
Default 82 Corvette with Heads and Cam LSx
Just the facts ma'am.
The Dyno Run
Play time at the track.
I'm building it to be a solid all-arounder with a slight bias towards road racing (eventually).
Old Nov 28, 2007 | 08:43 PM
  #650
halogrinder's Avatar
72 toyota landcruiser
2005 6.0 truck engine
turbo 400
np205 transfercase
Old Dec 2, 2007 | 07:15 AM
  #651
Sweethome AL's Avatar
I am building a 1948 Chevy 5 window pickup. I have the chassis complete with custom build coil over suspension in the front and leafs in the back. There is NO BONDO on any of the body. I am hoping to install a LS-1 along with a t-56 tranny.
THIS IS MY FIRST BUILD. So I am learning ALOT. and I dont know MUCH. If anyone has any tips, I am MORE THAN HAPPY TO LISTEN. Espeacially tips on how to make the tranny fit. I am thinking since it is a new build (and since the motor and tranny match) that the only thing I will have to modify is maybe the shifter. Since this is an OLD truck and there is not much space in the cab. It is good to be a member here and I hope to get some reply's on this. THANKS ALOT !!
Old Dec 2, 2007 | 03:26 PM
  #652
vettezuki's Avatar
Off the top of my head, here's the list of things you'll probably need to address you may or may not have thought of:
- Decide if you're going to go Fly By Wire (C5 Corvette) or mechanical (F-Body), This implies difference in throttle body, computer program, and even the intake in the case of LS1 intakes (I recommend the LS6 intake)
- Source for computer and harness (Painless Harnesses are really not that easy to work with) if it doesn't comes with your engine.
- You'll probably need some metal fab skills (not a trivial skill) to create a trans tunnel as I don't imagine the T56 will fit in that truck.
- Motor Mount adapters for proper location in the engine bay (may be available aftermarket as they were for my C3 Corvette)
- You'll almost certainly need a new drive shaft as the distance between the trans and diff wil change
- I like the Slik Stix shifter formally from McLeod. They come with many different offset options, so you can get the shifter to come up in the right location. Call McLeod and ask to speak to Red Roberts. It's not a McLeod stock item, you have to go direct to Red.
Anyway, here's a link to my conversion.
You may find some of it useful. Be prepared to spend more time and money than you originally anticipated to do things properly. Don't cut corners with cheap used parts for the driveline. Nothing is more annoying than a car with a nice engine and **** trans/clutch. Buy new where new is warranted. Take your time and good luck.
Old Dec 3, 2007 | 04:56 PM
  #653
jbontrager's Avatar
59 Pontiac Catalina getting an
ls1 and 4l60e tranny from 02 camaro
Old Dec 3, 2007 | 08:28 PM
  #654
unabomber's Avatar
84 chevy chevette 2 door "silver bullet"
LS1 T5? on an S10 chassis shortened and 3 or 4 linked rear
Old Dec 4, 2007 | 08:04 PM
  #655
clifton greene's Avatar
1968 ford f 150 need to install 1996 4.0 engine from T bird is thir a harnesshugurlips2@yahoo.com
Old Dec 6, 2007 | 01:29 PM
  #656
1974Nova's Avatar
1974 Chevy Nova, about to have a 5.3 in it. Here to gain some info on how to do it.
Old Dec 13, 2007 | 08:04 PM
  #657
LS1xtreme315's Avatar
2002 s10 xtreme ls1 t56
Old Dec 19, 2007 | 09:17 AM
  #658
Speed Demon's Avatar
98' M3, waiting on Vorshlag kit. 99' LS1 and T56 driveline.
Old Dec 20, 2007 | 10:43 PM
  #659
bowtieguy79's Avatar
79 Chevy C-10, 2000 5.3/4L60E
http://www.performancetrucks.net/for...d.php?t=406994
Old Dec 22, 2007 | 09:55 AM
  #660
Stovebolter's Avatar
Default 1936 Chevrolet Low Cab LS1 Swap
Just getting started.
LS1 into a 1936 Chevrolet Low Cab.
http://farm3.static.flickr.com/2194/...22764ac014.jpg
http://farm3.static.flickr.com/2071/...7a4f7a5dfa.jpg
http://farm3.static.flickr.com/2303/...0e7b7e687e.jpg
http://farm3.static.flickr.com/2151/...aebdd7ae57.jpg
Like I said...just getting started. I'll try to get a journal started. LS1/4L60E should be here next week...
