Conversion folks please list your conversion in here
Old Jan 16, 2008 | 08:06 PM
  #681
bigbass1307's Avatar
Default 83 chevy
1983 Chevy Short bed
305 to 5.3l Vortec
many headaches later its finally alive.
Old Jan 16, 2008 | 08:36 PM
  #682
Rottluver's Avatar
Originally Posted by drchapar
I have just received my 2002 Mercedes E, now with:
LS1
AFR Mongoose Heads
Long Tube Headers
T-56 6 speed
Centerforce dual friction clutch
Stebro Exhaust
SL 500 Launch edition Wheels - staggered
Brembo Gran Tourismo Front Calipers
H&R Sway Bars
H&R Shocks
Custom Stereo
E55 AMG interior (to be installed)
This may be the first of its kind done.
Pics??
Old Jan 20, 2008 | 08:48 PM
  #683
Absolutezero's Avatar
96 toyota tacoma -04 gto ls1 -custom suspension motor set back 15 "
Old Jan 22, 2008 | 05:45 PM
  #684
vapoppa's Avatar
2000 jeep tj wrangler with an '05 gto ls2 which has been up graded to a c5r 427, 092 heads, comp cam. the trans is 4l60e and an atls 3.8 transfer case. the axles are dana 44's with 3.73's. pic's to come soon---- mase
Old Jan 22, 2008 | 08:45 PM
  #685
fasthuhpat's Avatar
1979 chevette
2002 ls1 from a ram air trans am auto
http://www.hotrodders.com/forum/jour...w#LS1 Chevette
Old Jan 22, 2008 | 11:18 PM
  #686
65SSZO6's Avatar
$100 2004 LQ4 6.0L long block engine core from a 2500 Chevrolet truck. Rebuilt with Speed Pro 4.020 hypereutectic pistons,molybdenum rings,new bearings.Crankshaft turned .010/.010. Rotating assembly balanced.LQ4 camshaft and valve springs replaced with a 2004 Corvette Z06 Cam and matching spring kit. Truck intake replaced with 2000 Camaro(car friendly) LS1 intake, throttle body, fuel injectors, and fuel rail.Accessory drive from 97-Up Corvette used minus the air conditioning. Custom oil pan and pick up tube from Street and Performance. Stock 2002 GM ECU and wiring harness reprogrammed by owner with HPTuning software. Kooks headers and motor mount adapters. Custom intake tube with K&N filter.Going into a 1965 Chevelle SS
Last edited by 65SSZO6; Jan 24, 2008 at 10:25 PM. Reason: left out info....it was late
Old Jan 24, 2008 | 05:14 PM
  #687
Rottluver's Avatar
Did I miss what vehicle that is going into?
Old Jan 25, 2008 | 04:01 PM
  #688
deak350's Avatar
Default 63 Nova SS Convertible
LS1 / T56
Attached Thumbnails Conversion folks please list your conversion in here-img_1045.jpg   Conversion folks please list your conversion in here-rgtfront21.jpg   Conversion folks please list your conversion in here-img_0773.jpg
Old Jan 28, 2008 | 07:34 PM
  #689
BartMan63's Avatar
Default 63 Corvette LS1 -- just starting
I have a custom 1963 that I'm just starting to do some work on. My frame is kind of rusty, so I recently purchased a new Jamisons frame from someone who's changing direction with their project (meaning I got a pretty good deal). I also bought a 98 corvette LS1 motor with 46k and a few mods. I'm in the process of buying C4 Corvette suspension parts and other items. I need to get coil-over shocks, a Tremec TKO 600 transmission, electric fuel pump, new radiator and electric fans, etc.
I'm sure it will be a long project. If anyone has some pointers for me, I'm sure I can use them! Thanks.
Old Jan 28, 2008 | 08:29 PM
  #690
Lee@woodworks.ca's Avatar
Default 69 Camaro Convertible LS1 - T56 Swap Info
After 1 year of many long nights, I'm driving the old rag top with the new drive train. It goes like a scared rabbit and has the looks to match (IMO) Won the GM first choice award in the first show and shine, straight out of the exhaust shop to the show.
I couldn't be more proud of my first frame off restoration / conversion and had a blast doing it.
Lots of pics and helpful stuff at www.lees69camaro.com where I had as much fun documenting the swap as the swap itself.
Attached Thumbnails Conversion folks please list your conversion in here-new-paint-pics-057.jpg   Conversion folks please list your conversion in here-69-camaro-swap-042.jpg   Conversion folks please list your conversion in here-69-camaro-swap-044.jpg   Conversion folks please list your conversion in here-new-paint-pics-053.jpg   Conversion folks please list your conversion in here-new-paint-pics-081.jpg
Old Jan 28, 2008 | 09:57 PM
  #691
Boosted 99 TA's Avatar
2001 LS1 from a formula, installed into a 94 Z28.
Old Jan 29, 2008 | 12:56 PM
  #692
Swed55's Avatar
Hi
I am restoring a 1955 Chevy Bel Air with:
Engine LS6 410 Hp
Transmission 200R4
Chassi Jim Meyer Replacment Chassi
Old Feb 12, 2008 | 10:51 PM
  #693
ls1nova71's Avatar
Ok, here's my latest project, probably my dumbest idea to date, but hey, I figured it would be different, fairly inexpensive, and relatively easy. So, what I've got is a 5.3 I've had lying around for a while, so I thought I would put it in my wagon! It's a 1984 LTD Crown Vic, yeah the BIG one! Anyway, this is gonna be real funny when it's done, I hope to have it done by the Power Tour 2008, so look for me there, I'll probably be the only one there with this kind of car! If I make it, and your on the Power Tour, you WON"T forget this car!!! And yeah, I'm totally, completely, 100%, Out of my mind!!
Attached Thumbnails Conversion folks please list your conversion in here-front.jpg   Conversion folks please list your conversion in here-mn.jpg
Old Feb 13, 2008 | 12:37 AM
  #694
KC Henry's Avatar
Cant wait to see it done Eric. Do you plan to take it to the weekend Belton Cruises? I should have my LS1 Caprice there. I am actually planning on being in the World Of Wheels this weekend with it as well, maybe I will see you sweet rod or Nova up there ?
Old Feb 20, 2008 | 04:45 PM
  #695
ls1_miata's Avatar
1991 Mazda Miata
2002 LS1/T56, Ford 8.8 rear with 3.73 gears
Build website: http://home.comcast.net/~npartist/
Old Feb 29, 2008 | 09:44 AM
  #696
porsche914ls6's Avatar
Default LS6 into a Porsche 914
I was the first to put a LS series motor into a Porsche 914 (1998). The current engine is a modified LS6 putting out 520HP normally aspirated. The car is light (2500lbs) and goes like a demon! It also wins alot of autocross and roadcourse events. I'm ready to build an RCR Superlight Coupe with a 1200HP twin turbo LS7. I'm pretty sure that would scare the daylights out of me.
Attached Thumbnails Conversion folks please list your conversion in here-my-914.jpg
Old Feb 29, 2008 | 11:44 AM
  #697
andrew69_04's Avatar
have a 69 Camaro that i swaped in a a 2001 LS1and 4L60E combo, cammed it up and did a few other things.
My current swap (in progress) is my 2003 S10 Xtreme. Im putting a 2000 LS1 and 2002 F-body T56 into it. i have a thread on another forum if you want to check it out. heres a link.
http://www.s10forum.com/forum/f213/s...inally-339910/
Old Feb 29, 2008 | 07:39 PM
  #698
jsworkstd's Avatar
doing a LS6 in a 1968 Corvette Convt, look for it on Hot Rod Power Tour in 2008.
http://www.schwartzperformance.com/1968corvette.htm
Old Feb 29, 2008 | 07:42 PM
  #699
jsworkstd's Avatar
Here's a 1971 Cutlass with a stroked LS7.
http://www.schwartzperformance.com/CutlassLSX455.htm
Old Mar 1, 2008 | 09:40 AM
  #700
Checkmate's Avatar
Awesome idea, I love it.
I thought about a ls1 in a mid 80s crown vic.
