Paging SPEARTECH!!!! UPDATE ?????????,,,,,
Old Jan 21, 2003 | 06:45 PM
timelord's Avatar
Default Paging SPEARTECH!!!! UPDATE ?????????,,,,,
I am doing a tranny swap from M6 to A4,so far so good.
My car is a 94 Z28 T56 that does 12.5s with a 1.90 60ft.
I want to go to a 97 4L60e to run 12.0 with 1.60 60ft.
The 4L60e will be built to stand up to 10.sec runs with 9 clutch pack etc etc.
The converter is a COAN that will stall around 3000-3200.
The PCM will be programmed by Ed Wright for shift points and lock up only in OD on highway.
Ed says he has resolved the high stall problems with 94-95s.
My engine is 94/my PCM is 95/my tranny is 97.
Are they compatible???
If I face a problem,what is it please.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ January 28, 2003, 04:14 PM: Message edited by: timelord ]</small>
Old Jan 21, 2003 | 09:53 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Paging SPEARTECH!!!! UPDATE ?????????,,,,,
It looks like you have it covered.
As long as your PCM is flashed with a 95-97 calibration, and you have it wired correctly, you should be fine. 95 was the year they added the PWM torque converter control. That adds one additional wire from the trans to the PCM. As long as you are wired for that, you're there!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 21, 2003 | 10:54 PM
timelord's Avatar
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU
<img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
Old Jan 28, 2003 | 04:15 PM
timelord's Avatar
Is the 94 A4 harness and the 96 A4 harness the same[both missing TCC],other than that are they interchangeable?? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thank you!!
Old Jan 28, 2003 | 04:45 PM
Speartech's Avatar
Not sure if I follow you for sure.
The 94 does NOT have PWM TCC.
The 96 DOES have PWM TCC.
This wire is at position "U" on the round 4L60E connector.
John
__________________
www.speartech.com
Old Jan 28, 2003 | 04:47 PM
Speartech's Avatar
The VSS connector at the back of the trans is also different between 94 and 96.
John
__________________
www.speartech.com
Old Jan 28, 2003 | 05:52 PM
timelord's Avatar
Does the position of the crank sensor change anything????
Old Jan 28, 2003 | 09:29 PM
Speartech's Avatar
If you are using a 95 PCM, the crank sensor and post O2 harnesses won't be used at all. They'll just be dangling there. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
__________________
www.speartech.com
Old Jan 29, 2003 | 09:44 AM
timelord's Avatar
If I pick up the 96 harness is the VSS connector the same on the 97 tranny I am using??
These things aren't that easy to find I am discovering. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jan 29, 2003 | 11:23 AM
Speartech's Avatar
Yep, that's a match.
John
__________________
www.speartech.com
Old Jan 29, 2003 | 11:34 AM
timelord's Avatar
And the crank sensor is not a problem!!!
Remind me to buy you a few beers if ever we meet!!! <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
Old Jan 29, 2003 | 11:59 AM
Speartech's Avatar
The crank sensor was added for OBD 2 misfire detection ONLY. It has nothing to do with the running of the engine.
I'll remember the beers. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
John
__________________
www.speartech.com
Old Jan 30, 2003 | 12:03 AM
timelord's Avatar
So will I,thank you!!! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
