Start circuit 1035? (Ppl/wht wire)
I'm planning on connecting the fat purple wire that goes to the starter solenoid to a relay switched against a hot always wire. Then I'll switch the relay with my ignition switch, start position.
My worry is that this bypasses the PCM. The PCM will be on by virtue of the orange always hot wire and the 539 and 439 circuits (pink) that are ignition on. I have these pink wires connected to fused, ignition on lines. But doesn't the PCM need to have a "Start" signal?
But then, perhaps there's a wire running from the starter solenoid back to the PCM? I don't see a 1035 circuit on the PCM pinouts anywhere. Nor do I see any kind of pin labelled as "Start" or anything.
Worrisome.... Can anyone clear this up for me?
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
John
www.speartech.com
John
www.speartech.com
Anyway, I only let it run for 10 seconds or so. It doesn't sound too good. The SES light is on too (assuming I have it wired correctly - I have an LED connected to 12V+ on one wire and the brown/white wire from C230 on the other).
I still have a big wiring mess to sort out - rewiring the entire car from scratch. Still haven't got radiator hoses or proper intake plumbing.
Reading the codes and plumbing it for some extended running will go a long way towards a smooth running engine.
I finally had to build a variable rate injector cycler, so I could "prod" the injectors before even trying to start the engine. It's kinda nifty; if you have spark, you can actually run the engine with it by just turning the cycle rate **** until the engine smoothes out nicely!
John
www.speartech.com
But, it only ran for 10seconds, and I wouldn't expect it to run beautifully after sitting for well over a year.
I have to get a new ignition switch - right now I have to patch a hot wire over to that set of pink wires in order to start since for whatever stupid reason, my switch turns Ign. On to Off when the key goes to Start.
Also, as an aside, I have what, 5 pink wires (439, 539, 839, etc, etc), split out into 2 different 10amp fuses. I presume that's okay and that there's no need to fuse each one separately. Both fuses are fed 12v+ by the Ign.On line from my (broken) switch - no relay in between. I do have a relay for Acc.On and the Start circuit.
It didn't sound like it was missing - I dunno, it just didn't sound smooth. It was also much louder than I expected. Much. That may be the reason I don't think it sounds good. And I may have some exhaust leaks (I have 3 gasketed flanges in my system which is dual 2 1/2 off the stock manifolds Y'd into 3 inch to a MAC muffler).
I don't have a throttle cable hooked up, so it was just idling. I have yet to put new plugs in it. The wires look good. I got the motor from a wreck. Lots of battery acid damage to various bits and also I had to replace 2 coilpacks.
It was kind of a relief - I had tried cranking it like a dozen times - before I finally found that the ign switch was hosed. So, when I patched the wires, and cranked it and it fired right up - that kinda zapped my senses.
So, Now I need to track down a switch, then connect a real air intake system, radiator hoses, throttle cable - also fuel tank vent lines and a bunch of non-swap related vehicle wiring (I tore everything apart).
BTW, Cyrus, who also has a 240Z with LS1/T56 just posted his recent times on hybridz.org: 12.077@119.066 with a 60ft of 1.849.
