Engine Swap (LT1 for LS1 for LS6)
Old Feb 22, 2003 | 07:33 PM
Ravenous T\A's Avatar
Default Engine Swap (LT1 for LS1 for LS6)
I have a deal going with my father. He wants to put an LS1 in his 96 TA(Auto), I have a 98 TA(M6) that he wants the motor out of, in return he will go in half on a crate LS6. Whats is all involved in hooking up an LS1 into a 96 TA? Will the tranny hook up, what will i have to modify? What about the 96's AC unit, how will it hook up? And what other things do I need to know about so there are no surprises when we get ready to do this. I HATE surprises! Please I need Info so I can make this work for the both of us.
Old Feb 22, 2003 | 09:54 PM
whatever's Avatar
Default Re: Engine Swap (LT1 for LS1 for LS6)
Things I know.
The output shaft is different.
The motor mounts are different.
The entire intake setup is different.
There's more but my cab is here.
Old Feb 23, 2003 | 07:15 AM
WILWAXU's Avatar
Moving over to Hybrid section.
Old Feb 23, 2003 | 09:38 AM
srh00z's Avatar
What are you doing with the LT1?? I am kind of looking for one.
Old Feb 23, 2003 | 08:46 PM
John B's Avatar
Moderator
Try using the "search" engine. This has been done before.
Old Feb 24, 2003 | 12:37 AM
Not sure yet, I have to plan the conversion 1st, but the LT1 has 94k on it also. We are planning on doing next year, but I want to be prepared for when we do it.
<small>[ February 23, 2003, 12:38 PM: Message edited by: Ravenous T\A ]</small>
Old Feb 25, 2003 | 05:05 PM
94z28ls1's Avatar
Ok the breakdown in a nut shell
Change Cross Member (its easier that way)
Slightly modify transmission mount (adding about a 1 inch tab to make it work)
Of course modify the harness to match your interior wiring harness talk to speartech for that one.
your going to have a fuel problem that can be solved with an aeromotive adjustible fuel pressure regulator(make sure it has a return line on the bottom so you can use your stock fuel pump)
Vats will have to be disabled
The ac can be made to fit its just going to take some measurements after the install. If you have any questions in specific you can email me and i'll try to help all I can I just finished this same swap enjoy your new project and prepare for some hard wrench time to make it all happen
Old Feb 25, 2003 | 08:29 PM
66ImpalaLT1's Avatar
He shouldnt have a fuel return problem with a 98 rail.
Eric
Old Feb 26, 2003 | 07:32 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
All F-body fuel rails are single line, no return; regardless of the year.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
