Shorting Problem
Old Mar 15, 2003 | 05:49 PM
Lesrace82's Avatar
Default Shorting Problem
I went to start the car up today. Ran power to everything to make sure everything was kosher. Well the fuel pump turned on for a second and then quit. At which point I noticed that the PCM fuse had blown. I tried another fuse, This time there was no running of the fuel pump, and fuse instantly blew. I unplugged everything on the motor and tried another fuse, and had the same happen. So I walked away from it today, so that I could go at it tomarrow with a fresh perspective. Just wondering if any of you had any ideas about it? Think its a bad PCM? Wiring Probs? Any help would be appreciated. Also this is a LS1 with the 4L60E.
Bill
Old Mar 15, 2003 | 09:42 PM
John B's Avatar
Moderator
Default Re: Shorting Problem
I had the same problem. I had to use a 20AMP fuse going to the PCM instead of a 10AMP fuse. Problem solved (at least for me!).
Old Mar 15, 2003 | 10:41 PM
Lesrace82's Avatar
I even had a 20 amp blow on me, thats what I had in to begin with. I am going to unplug the computer tommarow and see if it still blows. Then I'll at least know it is a wiring related problem.
Old Mar 16, 2003 | 07:36 PM
Lesrace82's Avatar
My shorting problem is from the Vats module I bought. Its reading a dead short between the positive and negative leads.This is one I bought off of Ebay. Is there a certain way this is supposed to be hooked up or did I just get screwed on it?
Thanks
Bill
Old Mar 20, 2003 | 08:12 PM
Lesrace82's Avatar
Whos has vats modules for sale? Any sponsors sell them?
<small>[ March 20, 2003, 08:13 PM: Message edited by: Lesrace82 ]</small>
Old Mar 20, 2003 | 11:57 PM
jeromio's Avatar
I have one. I went ahead and had my PCM reprogrammed to eliminate VATS, so I don't need it.
I have the module, the ignition lock and the key that goes with it. The guy I bought my motor from used it to fire up the motor before I loaded it up.
Offer? $30 + shipping?
Old Mar 22, 2003 | 09:43 AM
Lesrace82's Avatar
How does it get hooked up? Just like a normal resister type module?
Old Mar 23, 2003 | 12:06 AM
94z28ls1's Avatar
I had the same problem but traced it back to my fuel pump grounding out. May be worth checking to make sure.
Old Mar 24, 2003 | 10:20 AM
jeromio's Avatar
The key recepticle has 2 wires running to the box (still connected), a black ground, then there's an orange and a red wire for power (I think only one needs power for VATS), pink ign. on power, and a dark blue wire that goes to the PCM (circuit 229). You can use the yellow/black wire to activate the starter relay (ground) if you use the ign. switch. I was going to just wire the thing in and stow it up out of the way, using my datsun switch. That way, if I chose to, I could reach up and pull out the GM key for added theft proofing.
It has a buzillion wires coming out of it to control all kinds of things, but for VATS, it's just those few wires.
Old Mar 24, 2003 | 06:30 PM
Lesrace82's Avatar
Take $25 for it?
Old Mar 24, 2003 | 10:41 PM
jeromio's Avatar
PM'd ya.
