Starter motor problem - HELP!!!
Old Nov 23, 2005 | 05:30 AM
robin427's Avatar
Default Starter motor problem - HELP!!!
I've got a 2002 LS1 in a kit car. Has been starting with no problems for ages now. Parked it in the garage yesterday but when I tried to start it today, the starter motor wouldn't turn.
I turn the key, get the fuel pump whirring for a couple of seconds. Press the starter button and get a loud "click" from the starter relay, but not even an attempt to turn the engine. I had a problem with a bad battery before, which made a "tick-tick-tick" noise from the starter area, but this is different.
Any clues?
Old Nov 23, 2005 | 07:15 AM
2004tr's Avatar
Robin
Have you checked all connections on starter and battery ?
These could easily have vibrated loose after your SVA trip.
Old Nov 23, 2005 | 07:49 AM
robin427's Avatar
It was a loose connection - thank goodness. Went into a bit of a flap there. Nearly paid you a visit after SVA (I did get REALLY lost on the way home and had to drive for miles down various back lanes before I got home!!)
Old Nov 23, 2005 | 09:52 AM
joelvette's Avatar
dont they put the starter on the other side of the engine over there across the pond?
Old Nov 23, 2005 | 12:31 PM
robin427's Avatar
Starter is on the driver's side in a right hand drive car - that would be the passenger side on the original. Mine is from a Canadian Firebird and was completely stock
Old Nov 24, 2005 | 04:18 AM
robin427's Avatar
Walked into that one
Old Nov 24, 2005 | 08:13 AM
joelvette's Avatar
yeh no offense meant. just couldn't help myself. got relatives in luton, I dont cut them any slack either.
Old Nov 24, 2005 | 03:12 PM
robin427's Avatar
I would if I were you... living in Luton can't be easy!!!
