Flexplate Help!!
Old Jan 18, 2006 | 09:33 AM
malibuman69's Avatar
Default Flexplate Help!!
I am putting a LS1 in a chevelle with a th350. I am not sure if the stock LS1 converter will bolt up to the converter or not? Does anyone have any ideas??
Old Jan 18, 2006 | 10:24 AM
EDS01SS's Avatar
Im pretty sure that everything will bolt up with a TCI flexplate.with a stock flexplate i believe you need spacers and a bunch of other stuff.
Old Jan 18, 2006 | 10:51 AM
z28evans's Avatar
Howdy,
I did this for over a year in our race car, using a couple of washers for spacers. Then the bellhousing broke. I have learned from the guys at Yank that the LS1 uses a different torque converter hub to align the torque converter. To do it right you need to get a torque converter for a ls1 / th350. This will take care of the alignment issues and you will NOT need to run spacers. Yank sells them, and i believe they are a sponsor to this site.
James Evans
Old Jan 18, 2006 | 03:26 PM
alright. I might have to do that. I dont like the idea of running spacers due to the fact i have a 4000 stall and when that thing locks up... there is alot of tq/hp resting on those three bolts. thanks alot for the ideas!!
Old Jan 18, 2006 | 05:28 PM
since the ls1 engine is internally balanced, will any sb flywheel with the correct bolt pattern work?
Old Jan 18, 2006 | 06:37 PM
80superbu's Avatar
Read THIS THREAD
Old Jan 18, 2006 | 06:39 PM
EDS01SS's Avatar
nope sure wont...you will need the LS1 specific flexplate from TCI
Old Jan 18, 2006 | 08:00 PM
alright, thanks for the post of that thread. that helped out a ton. I got all the answers... and some dam good prices on stuff.... Thanks!!!
Old Jan 25, 2006 | 06:55 PM
fash00's Avatar
anyone know what size bolts i need to order from arp to bolt converter to tci flexplate what size pitch and thread
Old Feb 9, 2006 | 12:00 AM
LS1HeavyChevy's Avatar
I bolted my LS1 to a TH350 with the 99-up style stock flexplate just fine with a B&M Torqmaster converter. I haven't gotten the car running yet, but I've heard of flexplates cracking in this swap and was told to get a lock-up or overdrive converter. I recommend trying to bolt them up without the spacer #12563532 and the long bolts because GMpartsdirect.com won't allow returns on them if you don't need them (like me).
