turn key nothing happens WTF
Old Feb 7, 2006 | 08:36 PM
lilicedout24's Avatar
Question turn key nothing happens WTF
ok what can be the problem 95 ta a4 fully converted to 98 ls1 & tranny dashboard etc... what can keep the motor from spining over? i can put a hot wire to the starter wire it starts but cuts right off any help is better than none thankx guys
Old Feb 7, 2006 | 10:02 PM
Slo_240sx's Avatar
If you are jumping power then your starter is okay and youre not getting power. The purple wire is your trigger wire off of your ignition switch. Check for continuity from the ignition switch to the starter... I'm not too familiar with F bodies but i am sure they have relays. If thats the case, check for power on 2 ends and ground on 2 ends. 2 will be power feeds 1 being key turned to start, 1 being constant power and 2 grounds, one being a ground for the coil in the relay to control the big circuit and the other going to the starter (which technically is not a ground but is because it will be a ground until given power to power the solenoid).
-Alex
Old Feb 8, 2006 | 09:19 PM
ok will check and see
Old Feb 9, 2006 | 11:07 AM
01WS6/tamu's Avatar
If you used your 95 column with everything out of the 98 chances are the vats is your problem. You will have to get the lock cylinder out of the 98 or if you have the vin from the donor car order a lock cylinder that will have the correct pellet in it. Or check your park neutral switch etc if the security light is not flashing.
Old Feb 9, 2006 | 11:41 AM
Mikey 97Z M6's Avatar
Or disable the VATS through a simple pcm reflashing.
Mike
Old Feb 9, 2006 | 12:56 PM
RFERG43's Avatar
Vats won't keep the engine from turning over. It would start for a second or two and then quit.
Old Feb 9, 2006 | 12:58 PM
ls1_chevelle's Avatar
Neutral Safety Switch?
-Matt
Old Feb 9, 2006 | 08:16 PM
ok fellas the nuetral safty switch can i bypass it some way. i don't know how you tell if its bad or not do it have something to do with a the black peice with a snap that by the shift or gray.
Old Feb 9, 2006 | 08:22 PM
homegrown TA's Avatar
i put a ls1 in my 96 bird and had the same problem...i just ran a push button start to mine, and am still using it. but sounds like you are having other problems i am not familiar with. i have no key. bypassed the ignition all together.
Old Feb 10, 2006 | 03:27 PM
Slo_240sx's Avatar
I reread your first post... sounds like you have 2 problems. 1) Won't crank, you got to figure out why youre not getting power with key to crank. Most likely its in your wiring, if you can shoot up some diagrams I can tell you what to bypass for your neutral safety switch. More than likely thats what it is or simple incorrect wiring. 2) VATS is killing after you jump the terminal to the starter. Simple flash or bypass module will cure that. Hope that helps!
-Alex
Old Feb 11, 2006 | 03:59 PM
ok so is there a way i can bypass the neutral saftey switch. ok and when i do start the car by jumping the starter it runs for 1 or 2 seconds and kill
Old Feb 19, 2006 | 05:55 AM
ok fellas i have my pcm at thunder raceing getting flashed and will update you all after monday
Old Feb 21, 2006 | 06:21 PM
ok finally she runs (still not from key)going buy a push botton right now! ok 1 quick ? once i put the it on can i in stall a alarm?
Old Feb 21, 2006 | 09:07 PM
Slo_240sx's Avatar
I don't see why not...
As to your no start you are going to have the jump the neutral safety switch. First check the power coming out of the wire that triggers the starter right behind the ign switch. If you have power there then follow the wire to where ever it goes. On an Auto it should goto the PRNDL switch and only activate in park or neutral. If its a manual its going to a clutch safety switch. Is it a manual or auto tranny first off.
-Alex
Old Feb 21, 2006 | 10:01 PM
its a auto
