CORBRETTA is born!
http://www.beretta.net/board/ib3/iko...9;t=261;st=195
http://www.ls1howto.com/index.php?category=1
Engine Flywheel Bolts (First Pass) 15 lb ft
Engine Flywheel Bolts (Second Pass) 37 lb ft
Engine Flywheel Bolts (Final Pass) 74 lb ft
Pressure Plate
http://www.installuniversity.com/ins...ch_install.htm
Install new flywheel and torque the 6 bolts progressively to 74 ft-lbs in a criss-cross pattern. Use a flywheel tool (or equivalent to hold the flywheel during torqing. (sorry no picture) Clean the surfaces the clutch will touch on the flywheel and pressure plate with brake cleaner. DO NOT touch these surfaces after cleaning. DO NOT touch the clutch lining! Oil/grease will reduce clutch life and hinder performance of the clutch!
Use a clutch alignment tool to hold the clutch in position and then install the new pressure plate tightening the bolts to 52 ft-lbs in a criss-cross pattern.
http://www.beretta.net/board/ib3/iko...r=1;&#entry223
http://i29.photobucket.com/albums/c2...T/c5-black.jpg
http://i29.photobucket.com/albums/c2.../c5-black2.jpg
To add to the latest project I am moving so the Beretta is on indefinite hold.
But I'll be back!!!!
Norm
http://www.seriouswheels.com/top-196...o-Jay-Leno.htm
Looks like a guy named Bernard Juchli lengthened the torque tube 14 inches. His home number is 626-355-0587.
Tim
Tim
bad link, it's not working.
*** edit *** this one ---> http://www.seriouswheels.com/cars/to...o-Jay-Leno.htm
