Welding Oil Pan
Thanks,
Andy1
I'm very curious to see how you progress... what you're doing might be my only realistic option other than the S&P pan. Are you worried about losing capacity?
I'm considering this in lieu of buying an LS1 pan. The only external difference appears to be the depth at the sump. Everything else LOOKS the same. I don't really know why the truck pan is deeper. According to my info, the truck holds one extra quart of oil. See attachement comparing the two oil pans.
Andy1
Isn't the sump on the Fbody pan actually longer front to back than the truck pan? We're also talking about removing a whole 3 inches of depth... that's a lot, isn't it? Do you think you'll be losing less than a quart of oil capacity?
Not saying it's a bad idea at all... I actually like your idea a lot. However the oil pan is a pretty critical part!
Check this post for a good amount of pics and info on welded LSx pans
Andy1
If you've got to modify, then you will need to be concerned about a few things:
1.) Warpage. As discussed above, welding on the pan will try to distort it. Bolting it to a flat plate or old block will certainly help. Also, somebody who is skilled at doing that kind of thing will have some other tricks to help keep it flat. And if it ends up warped, you may be able to have a machine shop "deck" it to make it flat again.
2.) Weld porosity / inclusions. The aluminum casting tends to soak up some of the oil due to casting porosity. Which makes welding on a used pan difficult. Might be best to bake the pan at 400 or 500 degrees to burn off the oil and get the pan good and clean (I wouldn't do it in the oven in the kitchen, your brownies might never be the same). Do whatever you can to get clean material so that your welds have the best chance of holding oil.
3.) Capacity after you're finished. If you hack 3" out of the sump, how much oil capacity remains? Would be a good idea to figure it out before hacking and chopping, instead of after you loose a motor because of insufficient oil. Just a thought.
'JustDreamin'
Derek
Andy1
good luck
olly
1) the total amout of oil in the system
2) the amount of oil in the pan available to the pickup at any given time.
In my opinion #2 is a bigger concern. Having more oil actually in the pan (rather than in an oil cooler) is important if you are doing a long WOT pull and your engine is consistently in the high RPMs. Your oil pump is pumping at capacity, and the oil doesn't have enough time to fall back through the engine fast enough to keep the oil pan full. Since all the oil hasn't fallen back down into the bottom of the pan yet, the pickup tube starts gulping air and your oil pressure falls. Your engine starts starving for oil and it's all bad news from there. Does anyone else worry about this when they start to modify their oil pan??
I guess it's even more critical for me because I am running a turbo setup.
Derek
https://ls1tech.com/forums/generation-iii-internal-engine/410840-modified-oil-pan-need-advice.html
On a side note: something I didnt realize was that gasket for the camaro pickup tube and the truck pickup tube were different. No oil pressure first time I started it with the truck pickup tube
. Put truck o-ring on and all is well.Derek
I had 2 separate pans welded up in an attempt to fit my Typhoon conversion, I wasnt quite happy with the results and ultimately ended up with this:
Shown above in the 'tacked' format, its getting final welded as I type this and hope to fit it to the engine with a pickup tube that fits as well.
This pan will be available from www.turbotime.us once all the dimensions are finalized.
The sheetmetal pan will require a remote style filter arrangement but thats fine, I wanted to run it anyhow to regain some lost capacity, and may consider running an oil cooler as well.
Also, fwiw, CANTON Race Products has an LS1 sheet metal oil pan that is probably very close to fitting but its $575+ Definitely a NICE PIECE but not cheap.
