LS1 into a Vauxhall Astra Coupe
Old May 3, 2007 | 03:47 AM
  #401
abo's Avatar
abo
Originally Posted by Team Dangerous
Aha! That'll teach me for jumping to conclusions. Seeing the motor in there with no PAS pump, putting 2 & 2 together, and getting 327!!!
Doh!
Hey Rob! Did you enjoy the weekend then. Good to meet you and your Jelly Babies
Old May 3, 2007 | 01:31 PM
  #402
Pete 1's Avatar
Originally Posted by chuntington101
Pete, are you going to try and get a mag to write and article in this when you have done??? I know PPC are very interested in LS1's into anything different!
Chris.
Yes Chris, PPC and Total Vauxhall want to refeature it too, as do HPm (Vaux own mag.) and Redline.
Old May 3, 2007 | 06:20 PM
  #403
lightfod's Avatar
Have been reading this thread since the get go but never posted because I'm a slack bastard
Now its all coming together I had to get on and just say what an absolute champ you are Pete!!
Its a damn shame that you aren't in Australia because I would love to see this car in the flesh, an absolute inspiration mate!!
Cheers to you mate!
Old May 4, 2007 | 11:43 PM
  #404
exodus's Avatar
or in the us for that matter!
Old May 5, 2007 | 12:45 PM
  #405
Pete 1's Avatar
Well, she started first time, but wont run, i.e. it`ll fire up every time, but that`s it
We think it`s a pressure sensor problem and wrong routing of fuel lines.
Old May 5, 2007 | 06:20 PM
  #406
Team Dangerous's Avatar
Check the airflow sensor. I've had similar problems with Bosch systems. They start, but won't run. Sometimes they'll idle, but when you touch the gas pedal, they die.
Pete, you must have fitted some monster stereo, some really big shiny wheels, or have you got a 12" tailpipe for Redline to want to feature it? DO NOT LET RENTON DRIVE IT!
Or did you mention the laughing gas..........
Abo - yes I did enjoy racing. But let's not hijack this forum, or bore these people to death with talk of near 180mph LS1 powered cars on a superspeedway.......
Old May 6, 2007 | 01:35 AM
  #407
Pete 1's Avatar
Redline featured it before mate, Dan Williamson, who is a freelance journalist, does articles for TV, Redline etc. etc. is a pal of mine and wants them to do it again.
It did run for around 3 minutes, but that was by pouring petrol into the cold start feed.
Looks like I need a fuel pressure sensor and a fuel pressure regulator.
Is there a fuel return to tank on the GTO ?
Old May 6, 2007 | 04:51 PM
  #408
Happy Jim's Avatar
Pete,
Describe your fuel setup for us please. (you show me yours and I'll show you mine etc etc )
You will need a regulator and the return line should go from the regulator to the fuel tank, unless you've put aftermarket fuel rails in place (in which case let us know what you've got).
Rgds
Jim
PS - shouldn't need a fuel pressure sensor though
Old May 6, 2007 | 06:41 PM
  #409
stevieturbo's Avatar
You can use a return system like you may be more used to. Just fit a FPR and set it to 4 bar, and do not attach a vac line.
Although once Paul is on the job, either way will work with correct tuning/mapping
Old May 7, 2007 | 01:06 PM
  #410
Pete 1's Avatar
Originally Posted by Happy Jim
Pete,
Rgds
Jim
Thanks Jim, here`s a couple of pics ...
In the first pic, you can see the supply coming through the bulkhead going to the filter and then to the rail.
Tha other connection, which joins the throttle body, we thought was a return, but then thought it was a cold start and poured petrol down through the plastic pipe. When we did this, the engine ran for about 3 minutes.
Looking through the Holden engine manual, it gives, what we thought was a cold start, as a fume pipe ????
I`m now totally confused
Old May 7, 2007 | 02:02 PM
  #411
digitalsolo's Avatar
The fitting in the last picture is EVAP purge.
Old May 7, 2007 | 04:16 PM
  #412
Happy Jim's Avatar
Pete,
By accident you've sussed the problem
The pipe your tipping fuel down is the EVAP system, at pre-determined engine temps/revs it will open and allow in all those nasty fumes from the fuel tank (once they've been through a charcoal cannister first) directly into the inlet tract.....hence why your motor runs if you tip fuel in there.
I'll see if I can draw a micky mouse picture (my skills stop at about that level!!) of my fuel system in a moment. But basically you should have a high pressure pump in the rear somewhere, plus a regulator...picture coming up.
Jim
PS, my guess at the moment is that you don't have the pressure right.
Old May 7, 2007 | 04:32 PM
  #413
Happy Jim's Avatar
Pete,
Here's what you should have.
Rgds
Jim
Attached Thumbnails LS1 into a Vauxhall Astra Coupe-fuel-system-jims-ls1.jpg
Old May 8, 2007 | 01:11 AM
  #414
Hersker Hans's Avatar
Ive got the walbro 255 pump and an aeromotiv regulator. And if you look on ebay you get a fuel press instrument you can mount on the fuel rail or the regulator, i bought everything on ebay. Works great.
Then you turn the ignition on, look at the pressure gauge while the pressure is building, mine was set at 2 bar from aeromotiv, then you turn a bolt with an allen key on the regulator until youve got right underneat 4 bar (58) PSI, if youre not running a turbo you dont really need pressure from the inlet to the fuel regulator.
Old May 8, 2007 | 11:23 AM
  #415
Pete 1's Avatar
Thanks Jim, and Hans
Old May 8, 2007 | 08:42 PM
  #416
nofxrxmxpx's Avatar
this thread rocks.... keep up the good work
Old May 9, 2007 | 09:33 AM
  #417
Steve VanS's Avatar
Hey Pete
You are awsome -- very quick and craftsman work --
See Stu Cool on this forum for the combined fuel filter/pressure regulator as used on the '99 Corvette. It has an input from tank and return line back to tank on one end; the other end has an output to the single-line fuel rail. It regulates to the required 55-60psi needed. It uses the GM push connectors for fittings.
If you can not source this filter/regulator where you live, I'll get one for you and send it gratis ... glad to contribute to your project! Send me info re: address, etc.
Steve & Garret doing E30-LS1 conversion.
Old May 9, 2007 | 11:33 AM
  #418
craz28's Avatar
Pete,
You my friend are the man! Fantastic work!
Old May 9, 2007 | 01:47 PM
  #419
Pete 1's Avatar
Thanks guys
Thanks Steve VanS , whereabouts are you ?
Old May 10, 2007 | 08:26 AM
  #420
383 Holden Torana's Avatar
Hey Pete!
I received the link to this thread from an Australian Holden Torana forum and i've gotta say you've done a damn fine job! Just looking at an Astra, it's very hard to imagine an LS1 actually fitting!
Your labour of love will pay off, I rekon it will be an absolute beast to drive!
Well done mate!
Keith
